Old 02-17-2005, 07:39 PM
bhco bhco is offline
front axel (left side) leaking diff. oil
Drivers side front axel is leakingdiff. oil. Where is the axel seal and how to replace it? Please Help
Old 02-17-2005, 09:07 PM
JDPascal JDPascal is offline
Re: front axel (left side) leaking diff. oil
The axle seal on the drivers side is likely just outboard of the differential carrier. The passenger axle seal is inboard of the command trac shift motor mount.
To change the drivers side axle seal you need to remove both axles and the differential carrier so while you are in that far, you might as well change both axle seals.
JD
