Old 02-17-2005, 07:37 PM
agustincorrea agustincorrea is offline
Question Turn Signal installation on Outside Mirrors
I ordered the lenses of left & right Door Mirror. I have a Chevy Trailblazer 2004 LS which does not have this option. IF there is a Wire harnes that I can use to connect the light bulb of the Signal Repeater?
Or I may have to install new wiring up to the turn signal in hte fron head lamp since I found the Light blue Pos. wire that feeds only the Signal Light? Does someone has done this Six Sigma Project. Need help?
Old 02-17-2005, 10:32 PM
JoseEspino JoseEspino is offline
That's also an ongoing project of mine but I'm looking around for a wiring harness that should connect the turn signal socket instead of doing a custom wiring to tap into the main turn signal module.
Does anyone have an idea where I can get the harness? Thanks!
Old 02-18-2005, 10:16 AM
lkurek lkurek is offline
Re: Turn Signal installation on Outside Mirrors
There are turn signal feed wires running into the drivers and passenger side control modules (switch assemblies). Just run a new power and ground wire down from the mirror to the module, and your good to go. Some guys tap into the wires, I ALWAYS like to get a correct set of terminals from the dealer and wire it right into the plug....
Old 02-18-2005, 07:50 PM
Re: Re: Turn Signal installation on Outside Mirrors
We're is the Left and Right side module located? HELP!!!
[email protected]
Old 02-18-2005, 07:57 PM
Are the Modules on each door or in the Dashboard as well???
Old 02-19-2005, 11:41 AM
I found a Dark blue wire which is on under the Lock doors switch in the PAssenger side that only works with the right turn and the HAzard lights using a tester. The same for the left side, the only difference was that the left side the wire is Light blue. The only thing that gave me hard time was passing the wires from the Mirror to the inside panel of the door. Had to drill a little hole and carefully paas it until I got it inside the door. The best way to do this is removing the fornt panel of the mirror wich is attached with clips. As of now the Signal lights are working perfect.
Thanks,
Agustin Correa
Old 02-22-2005, 03:17 PM
Only time spent was crossing wires inside the mirror to the other side of the door. Had to do a small hole to pass the Positive and Ground wire. After that process job was completed in a couple of minutes.
Can the socket use a higher wattage bulb?
