View Poll Results: what is a better all round swap in a 91crxsi
d16z6..d16y8 with 500 dollars of bolt on mods 9 14.75%
d16a6 with turbo no more then 6psi 14 22.95%
b16a with lsd cable trans. 22 36.07%
b18b thats it nothing more just the swap no lsd trans. 6 9.84%
b20b thats it nothing more just the swap no lsd trans. 10 16.39%
Voters: 61. You may not vote on this poll
Old 02-17-2005, 07:31 PM
kingpinn's Avatar
kingpinn kingpinn is offline
motor poll
please take the poll and dont start fighting over what you think is better this is not a motor war i just want to see what every body thinks .
....thanks...
Old 02-17-2005, 07:34 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
so im not seein a poll here
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 02-17-2005, 07:36 PM
devaney devaney is offline
Re: motor poll
yeah i dont see it either
Old 02-17-2005, 07:40 PM
kingpinn's Avatar
Re: motor poll
do know what i did wrong sorry
Old 02-17-2005, 07:41 PM
kingpinn's Avatar
Re: motor poll
look up there its there
Old 02-17-2005, 11:19 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: motor poll
500 in mods wont get you far..., i say b20 for the most torque. 6 psi wont get you far either. I have a friend boosting 12 psi on a stock LS.
1991 Honda Civic DX Sedan
Old 02-18-2005, 08:44 AM
viper_2_4's Avatar
viper_2_4 viper_2_4 is offline
Send a message via MSN to viper_2_4
Re: motor poll
why no ZC?
Old 02-18-2005, 10:12 AM
kingpinn's Avatar
Re: motor poll
im not a fan of the zc because performance parts are a little scares for my liking but i did think about it
Old 02-18-2005, 10:13 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: motor poll
on a properly build D block you should be able to boost 10+ psi - my plans are to boost 8 psi at the most since it is my daily driver
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 02-18-2005, 10:21 AM
kingpinn's Avatar
Re: motor poll
icE_x smart man i never herd that you could boost that much on a d.. This crx will be a daily driver to . well thanks for the info.....
Old 02-18-2005, 11:16 AM
honda_luvr_2000 honda_luvr_2000 is offline
Re: motor poll
it all depends on wut u'r goals r and wut kind of performance driving u plan on doing w/ the car.
if it's road coarse, then u'd want to stick w/ a D-series to save weight and not get understeer, prolly go w/ the Z6 or Y8, maybe the turbo A6, cuz u'r also gonna need more money in suspension and roll cage.
drag racing, a properly built B20 w/ a B16 head and LSD tranny would get u FAR FAST. i see that wasn't an option, but it's a mix of two.
autocross, again the lighter D-series, like the Z6 or Y8 and only 500 in mods, because again u'r gonna need the money in other areas and to save weight.
as a side note, the reason i said stick w/ the d-series in road corse, even though there are open straights. my buddy races a CRX in the H2 class of NASA, and he has always used a A6. He just got his new engine last month, and it's another A6, but this puppy has more than $10k invested in it from his sponsor. So a A6 motor w/ turbo sounds like fair game. By the way, his new engine is all-motor, and he told me has 310hp at the crank (but i'm a little skeptical). Once it gets warm again around here (OH) he's back out on the tracks, and I'll be there.
Old 02-18-2005, 11:37 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: motor poll
310 to the crank... I smell bs. But an A6 can handle a lot of compression and will scoot along quick.
From personal experience, I can tell you that if you drive on curvy roads with varying altitudes, the d16a6 (with lightweight components) matched to the si tranny can be very fun to drive...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 02-18-2005, 12:12 PM
kingpinn's Avatar
Re: motor poll
im sorry i should have said that it will be made for the drag strip . but i will still drive it to work every day ....
thanks
Old 02-18-2005, 04:01 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: motor poll
b16 will be the fastest out of all of those choices, followed by b20 and b18 which arent far behind. and after you can boost the b16
Team Lonely Drivers
Old 02-18-2005, 04:30 PM
SiZ's Avatar
SiZ SiZ is offline
Re: motor poll
YAY! B16 gets my vote again. It will be quick in basically stock form (not comprimising reliability), and can handle daily driving just fine because its meant to be revved like a fahker.
B20 with a B16 tranny would be a bit faster I would think, but with my B16 tranny it revs at 5,000rpm @ 80mph. I drive about 30 minutes at 80mph constant both to, and from work so I want something thats okay with keeping constant revs like that.
I'm not saying the B20 might not handle it, but I don't know as though I'd want to be driving that close to redline for extended periods of time.
