'94 1.9 eratic iddle
My 94 1.9 has an eratic idle.It goes from almost stalling to about 1000rpm and back constantly.It usually will cut off if left alone.I have replaced the fuel filter and run cleaner through it but it still does it.Any ideas?
Re: '94 1.9 eratic iddle
My daughter's 1993 was doing that and it was the throttle position sensor.
my '94 pony did the same thing...it was the throttle position sensor.
These are from some posts I found when researching my problem about jerking & bucking.
Thought they might come in handy dow the line... Might check this out: "
Locked, Lifted & Geared: www.tomstj.com |
I agree with all the posts above. I have fixed cars that hesitated at different speeds by replacing the Throttle Position Sensor. The TPS is nothing more than a rheostat (variable resistor) and can be checked with a VOM to determine if it is faulty and needs replacement.
I have also fixed cars with idle problems as described by removing the air bypass valve, dis-assembling the solonoid from the valve itself, and oiling the orfice tube where it slides into the solonoid. This also improves acceleration, if it was sluggish. A quick check to determine if the Air Bypass Valve is working at all....disconnect the connector and the RPM should drop.
Alvin A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED. |
Where is the by-pass valve located?
Re: Re: '94 1.9 eratic iddle
Most of all ford tps's test normal even if they are dead. when you take off the tps make sure you look at the condition of the throttle part that sticks into the sensor because i have seen that rusted out and makes it idle like shit. Mine got so back it was starting to idle at 3500 and it was pissing me off i ended up getting a new throttle body. |
1999 Escort SE 2.0 ltr sohc, 5 speed - old one 1999 Escort SE 2.0 ltr sohc, auto - new one 2002 Dodge Grand Caravan sport 3.3, auto located in beautiful New England. "You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks |
Re: Re: Re: '94 1.9 eratic iddle
You say "Most of all ford tps's test normal even if they are dead." I disagree, if the method you use can not determine 'good' from 'dead' TPS then it hasn't been tested properly. A TPS may be tested on or off the vehicle using a DVOM. Testing the TPS will help locate burned or open spots in the variable resistor inside it. FYI: The proper test method is: 1. Connect one lead from the DVOM to the center terminal of the sensor. Connect the other lead to either one of the remaining two terminals. 2. Set the DVOM to the 20K ohm scale. Depending on the type of sensor, slowly turn the TPS while watching the meter. The meter reading should increase or decrease smoothly as you operate the sensor. Glitches or momentary infinite readings indicate a defective sensor, and should be replaced.
