Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 02-17-2005, 07:04 PM
visualon visualon is offline
1994 door panel ... how do i remove
The passenger side mirror is loose, and it appears that I will need to remove the door panel to tighten the mirror.. Can someone tell me how best to remove the panel and where the screws/clips are located? Also, if clips... will I need a special tool or will a screwdriver work?
thanks!!
Bob
Old 02-19-2005, 05:28 AM
gn1220 gn1220 is offline
You will need to remove the screws in the armrest, the screw at the bottom of the door, in or near the map pocket, I think there's one behind the handle too. Then, gently pull the panel away from the door starting at the bottom. Plan on replacing all of the clips because they barely hold the door anyway. It would be best to get a tool from O'Reilly Auto Parts to pull the clips because our door panels suck and pulling on them only puts more stress on the cheap plastic. The tool just slides behind the door panel and allows you to pry it loose.
Old 02-21-2005, 05:19 PM
Re: 1994 door panel ... how do i remove
Many thanks gn1220 !! Will check with O'Reilly about ordering this clip puller and picking up some spare clips before attempting this... The location of the screws have been driving me nuts... well hidden! Again, thanks.
Bob
