Old 02-17-2005, 06:45 PM
73Eleanor's Avatar
73Eleanor 73Eleanor is offline
Send a message via AIM to 73Eleanor
1981 Mustang Hatchback ????'s
I'm looking at an '81 hatchback, and there is a switch inside the car under the dash that says 'amp pull'. I've seen it on a '79 also. Does anyone know what this switch is for??!!
Old 02-18-2005, 12:22 AM
73Eleanor's Avatar
Re: 1981 Mustang Hatchback ????'s
I also own a '91 4cyl that is having trouble. The car will not turn over. It will sir there and try to crank all day long but just won't turn over. I've replaced the fuel pump, checked the distributor to see if the timing was off, new spark plugs and wires; just can't figure out why it won't turn over. So if any body might know what wrong and how to fix it i'd appreciate it.
Old 02-18-2005, 12:23 AM
benchtest benchtest is offline
If it's the switch I'm thinking of, it turns on the amp for the premium sound system. It was integrated into the radio in '85.
Remember: Don't confuse noise with horsepower! and Junk is junk, even when it's on sale!
"I would never doubt your expertise....it's obvious you wrote the book on stupidity!" DD
Old 02-18-2005, 12:39 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Re: Re: 1981 Mustang Hatchback ????'s
How did you check the timing if it wont run?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-18-2005, 03:49 AM
73Eleanor's Avatar
Sorry I didn't mean timing, I meant I changed out the distributor caps and all that junk.
Old 02-18-2005, 03:53 AM
73Eleanor's Avatar
I'll check and see if it goes to the sound system. I mean the car doesn't have a radio(head unit) but i'll check and see how speakers it has and if would be considered a 'Premium' sound system.
If theres any other ideas out there please let me know.
Old 02-18-2005, 10:17 AM
LI-SVT LI-SVT is offline
The speakers have the word "premium" marked on them for the premium sound system. A '79 Premium sound system by todays standrds would be pretty lame anyway.
