Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-17-2005, 04:58 PM
p71 JD's Avatar
p71 JD p71 JD is offline
Sorry K & N!! lol
K & N!!!!!!!!
Old 02-18-2005, 07:43 AM
0311_lifer 0311_lifer is offline
Re: Sorry K & N!! lol
i think you should only use the motorcraft ford recommended air filter on your car. im not too sure about this so any one correct me if im wrong but ive heard that something about the k&n air filters on a crown vic will mess with your mass air sensor or something. k&n makes really neat oil filters though because you can use a socket to install it and take it out but im not sure if they are that great for crown vics either.
Old 02-18-2005, 09:30 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
thats crazy i run one in my 92 grand marquis and it runs fine i was told that when u put one in to disconnect the battery and touch the two cables together to clear all the power in the comp's
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 02-19-2005, 12:19 AM
take pictures of yourself touching those two cables togeather. ill give you a cookie.
Old 02-19-2005, 12:01 PM
all u have to do is use something metal to touch the two cables together scence they wont reach
Old 10-01-2005, 09:45 PM
UNO#1 UNO#1 is offline
I have a K&N in my car. To everyone that says it doesn't add any horsepower, poo on you. I noticed a significant increase in speed after puting it on. And it was more than just 1hp
Old 10-20-2005, 07:47 PM
Re: Re: Sorry K & N!! lol
Use your head. There won't be a big shock if he does that, there is no power going to the negative battery cable when you disconnect it. So if you touch them, it won't spark. But it is good to see we have some smart people in this forum.
Old 10-23-2005, 12:22 AM
BiggerJon BiggerJon is offline
if you put in a k&n panel filter, you will see zilch in power.
if you use a fipk, you will see some gains. and for some reason the panel filter will mess up our maf's, but the fipk do not seem to.
using either will cause more dirt to get through. so be careful.
Mods
Old 10-25-2005, 01:01 PM
fleettech fleettech is offline
the reason they mess up the MAF is people over oil them and it coats the sensor.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
