Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 02-17-2005, 03:16 PM
willski2k's Avatar
willski2k willski2k is offline
Cyl' Head Temp' Sender into D16 ?
Hi ppl
Im in the UK and looking to fit a Cylinder Head Temp' Gauge to my Civic.
Its a D16Y2 Motor, has any body fitted the sensor into the cyl head b4, as it requires drilling and tapping a 7/16 NPT thread into the head casting, and Id like suggestions as to where is a safe place ?
Cheers
Old 02-17-2005, 06:55 PM
lorunner lorunner is offline
Re: Cyl' Head Temp' Sender into D16 ?
Head temp as in coolant ?
Stop asking me about radio codes I cant get them anymore!!!
Old 02-17-2005, 10:31 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Ok so why do you want a coolant temp gauge? Your car already has one from the factory, or are you talking about something else?
Old 02-19-2005, 12:40 PM
willski2k's Avatar
It measures the head casting temp. to avoid over temp damage
AUTOMETER CYLINDER HEAD TEMPERATURE GAUGE
Part No 3336
Cylinder Head Temp. 140°-340°F
Includes electric sender. May be necessary to drill and tap threads into cylinder head.
Old 02-19-2005, 05:43 PM
whtteg's Avatar
Do you really need the sensor though is what I was wondering? I mean do you have something abnormal that would require it? It is not really that common that the head would over heat without the coolant temp going way up, or at least to my knowledge.
Old 02-20-2005, 07:00 AM
willski2k's Avatar
m8 Im using a zex wet nitrous, and wanted a fast indicator of the aluminum casting temp'
the electrical sender of the cyl' head temp' gauge is a far faster response than the stock water temp (which wouldnt increase till way after id melted the head)
check out the car through a link in my sig'
Old 02-20-2005, 07:31 PM
whtteg's Avatar
Gotcha, have you looked to see if you can find a place where there is supose to be something bolted up but there is nothing. Like it did not come with that part? If so you could just drill out the hole and tapp it. I am not familiar enough with your motor to point out a spot. Maybe I can find some pics. I will post back if I can find something for you.
Old 02-22-2005, 07:50 PM
isn't that an exhaust temp gauge?
