Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 02-17-2005, 02:04 PM
gnrlbzik gnrlbzik is offline
Exclamation Altima 99 modifications/tuning questions?
Alright, here is the deal i own 1999 Altima GXE and i like the car and dont want to get new one but would like to modify it, something more like a project thing. So if any of you have sugestions, to what could work better.
At this point before i get to paint and additional out side look modifications. Although i ve got new sound system : ). Anyway here is the question.
- What could i max out of engine that i have right now? and how much would it cost.
- I know i probably wont get much so i came up with an idea what if replace my enigine with Infinity J30 engine instead of my own its 210hp, would it fit my transmition or will i have to get new one, and what would fit as new transmition.
thats it, any other sugestions?
Old 02-18-2005, 02:16 PM
TheQuietThings TheQuietThings is offline
Send a message via AIM to TheQuietThings
Re: Altima 99 modifications/tuning questions?
my suggestions...
dont take out the ka24de engine
you could easily find a turbo it that puts 260 to the wheels assuming you have a manual transmission. if you have an auto, then i recommend keeping it all motor.
anyways, since the 99 altima has been around some time it has a lot of aftermarket support.
CAI
CatBack
Turbo kit. i mean of course, you could build your own turbo set up. [ intake exhaust manifolds, turbo, intercooler, injectors, boost controller... etc.]
all of that without install would probably add up to 5500 beans.
260 HP to the wheels in such a light car [2800 lbs] with a factory installed LSD is going to have a lot of balls. a lot of people under estimate the 1st and 2nd generation altimas, but these cars can be made into good street racers without spending a ton of money.
Old 02-20-2005, 10:40 PM
op012503's Avatar
op012503 op012503 is offline
Send a message via AIM to op012503
you could piece together a turbo kit for the ka for about 2500 and most shops charge about a thousand for install. However if u have a higher milage ka i recomend swapping it with the FWD sr20det. I believe it came in the jdm nissan pulsar
Current ride is a 2000 altima 5 speed-Check it out!
http://www.cardomain.com/memberpage/755387
Old 02-22-2005, 11:27 PM
i dont recommend swapping that engine into it, you have a FWD car, and the KA produces more low end torque, making it a better drag car, opposed to the sr20det engine, which is made for drifting, and good luck drifting in a FWD car. Just my opinion, not looking to start a fight
Old 02-26-2005, 09:22 PM
op012503's Avatar
For reliability reasons i think that swapping to a factory turbo motor is better. I own a 00 and the engine is a little different. One thing is that the comp ratio is up to 9.2 i believe and its pointless to turbo it. Im swaping mine for an sr20det.
Old 02-27-2005, 02:01 AM
Re: Re: Altima 99 modifications/tuning questions?
unless hes looking to run really high boost, he will be fine, the ka24de is built to handle 400hp on stock internals
