Old 02-17-2005, 12:48 PM
CF5150 CF5150 is offline
Electical Problems
I have owned my 2001 Blazer LS 4X4 for about 3 months now. It has about 71,000 kilometers (about 44,000 miles) on the odometer. I have some wacky $#!& going with the electical. Every once in a while, as I am driving, I get a sudden loss in electrical power causing everthing electrical to shut down. It only happens for an instant, and the vehicle does not stall when this happens. However, when power returns, the clock on the Cd unit is reset to 12:00 and every light on the "information center" on the guage cluster is lit up. A few seconds later, everything returns to normal. And now I am coming across a new problem. Every so often it wants to stall when at idle. If you don't keep your foot on the gas to maintain 1000RPM or higher, it stalls and all the lights go very dim. My initial guess would be an alternator. Anyone got other any ideas?
Old 02-17-2005, 02:13 PM
Fireplug Fireplug is offline
Re: Electical Problems
Sounds like a loose or crudy battery cable or ground
Check and see if the cables are loose on the battery
Clue, clock reset means you lost all battery power
Old 02-17-2005, 03:05 PM
Cam1959 Cam1959 is offline
my guess is since reving motor makes differance, you have loose wire connection, dirty/corroded wire connection fitting or bare wire grounding out in motor area that is moved when motor moves from reving ... unplug/replug/check tightness/cleaness on all connectors that might be moved from tilting motor. are any near hot areas that may have burnt insulation ?
Old 02-17-2005, 03:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Sounds like a short somewhere.
I would clean and tighten the battery connections.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-18-2005, 08:57 AM
ricksza's Avatar
ricksza ricksza is offline
Check your positive battery cable connection. Delco has a problem with leaking batteries at this terminal.
Old 02-21-2005, 01:16 AM
sockeye3 sockeye3 is offline
Mine did about the same thing. AC Delco battery positive terminal fell right out. It may also be leaking and destroying your cables as mentioned earlier.
Old 02-21-2005, 02:07 PM
Hey guys, I removed and cleaned the terminals from the battery and made sure they were secure when I replaced them. So far, so good. It didn't have the O.E. AC Delco battery in it--must have been replaced.
Old 02-21-2005, 02:26 PM
BlazerLT's Avatar
AF -Advisor
Excellent!
