The 4WD on my '99 Cherokee sport works but once I am engaged and try and disengage it sometimes stays in 4WD. When it finally comes out, it does so with quite a large thud. Any ideas on what the problem is?
Also, my fuel gauge only works intermittently. It sometimes reads correctly and other times reads as empty. Again, suggestions? |
Re: 4x4 and fuel gauge problem
Check for a clean ground for the fuel sender on the fuel tank or in the instrument cluster. If the 99 4wd is operated by a vacumn - check to make sure you dont have any leaks in the system. I believe there is a cannister up under the front bumper. |
Chrysler also has issues with the fuel level sending units. Unfortunatly, you can only get that with the pump assembly from the dealer. Big $$. I used my trip odo for about a year until my wife ran out of gas one day...then I had to replace it
Steve '98 JGC (ZJ) 5.2L, Aluminum Radiator w/Electric Fans, 4" Cowl Induction Hood Scoop, Custom High Flow Air Filter, Magnaflow Cat / Flowmaster Super 40 Exhaust, Engine Oil cooler w/ remote filter, In-roof 8" DVD, Profile 600 Watt Amp, Kenwood 6.75" 3-ways, NV242, 3.5" Lift, RS9000s, 31x10.50x15 ATs, Proline roof rack w/ spare tire mount and 4 Hella 550s. |
That kind of a failure will get the car fixed every time
