Go Back   Automotive Forums Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 02-17-2005, 10:40 AM
peter i's Avatar
peter i peter i is offline
Send a message via AIM to peter i
Question Atlantic Fomula engine (Pic & Q.)
Only thing i can find is some website are selling this formula car (old fomula car) So i looking around . those spec are old but useful infomation for a fever fans like me ...
History
SCCA W Car Formula Atlantic and Pro- Formula Atlantic Series 1987-1990.
Recent Competition History
1989/1990 Marc Bahner Cup West Coast and Pro-Formula Atlantic Series
Performance Data
Class: SCCA PRO Formula Atl
Weight: 1225 lbs
Engine
Engine Builder: Paul Hasselgren
Manufacturer: TOYOTA
Type: 4A -GE / MR2
Displacement: 1600
Horsepower: 240+
Induction: CARBURETORS 48 WEBBERS
Heads: 4 CYL OVERHEAD CAM 16 VALVE
Block: 1600 TOYOTA
Crankshaft: STEEL BILLET
Connecting Rods: H BEAM
Pistons: FORGED TRO
Camshaft: TWIN
Valve Train: DUAL OVERHEAD CAM 16 VALVES
Clutch: 3 DISC BORG/BEC
Pressure Plate: BORG/BEC
Flywheel: STEEL
Total Time: 100 MILES SINCE REBU
Fuel System
Fuel Cell
Manufacturer: MARSTON EXCELSIOR LTD
Capacity: 17.4
Fuel Pump: ELECTRIC
Fuel Type: 103 OCTANE RACING
Oil/Water System
Radiator: YES
Water Rad Location: SIDE PODS
Water Pump: FRONT
Oil Cooler: YES
Oil Cooler Location: SIDE PODS
Electrical System
Ignition: HOWARD CRANK FIRE
Alternator: N/A
Battery: 12 VOLT
Computer: N/A
Transmission
Manfacturer: HEWLAND
Type: 5 SPD
Gears: VARIOUS RATIOS
Shifter: H - PATTERN
Trans Cooler: YES
Rear End
Manufacturer: FT-200
Type: QUICK CHANGE
Cooler: YES
Ratio: VARIOUS
Case: TRANSAXEL
Differential: HEWLAND
Axles: CV JOINT
Body
Construction: MONOCQUE / ALUMINUM / FIBERGLASS
Color: BLACK/GOLD
Paint: PPG
Condition: GOOD
Chassis
Type: MONOCQUE RALT RT-4 1983
Builder: RALT AMERICA LTD.
Material: FIBERGLASS / ALUMINUM
Condition: GOOD
Front Suspension: WIDE TRACK / ROCKER GOOD COND.
Rear Suspension: ROCKER TYPE GOOD COND.
Shocks: FOX SHOCKS
Brakes: LOCKHEED 4 PISTON COCKPIT ADJ.
Steering: RACK & PINION
Wheels: 13
Tires: 13
Is it possible to build it from scrap ? I gonna ordering a used 4AG (AE101) engine , and start a rebuild project on it ...Hope that anyone can surpport me a with a little info and experince to help me out ...thank you
Old 02-17-2005, 08:13 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
To build the formula atlantic engine part by part is roughly $11,000. You can buy a knock-off version (practically same specs) for around $10,000. The other thing is that these engines do not last very long, and for a daily driver would be a terrible idea.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 02-18-2005, 11:11 AM
SabreKhan's Avatar
SabreKhan SabreKhan is offline
The middle pedal is bad
Re: Atlantic Fomula engine (Pic & Q.)
daily driver?!? I didn't see anything in his post about a daily driver, but yes, it would be a horrible daily driver.
Look at the teeny picture of my car!
2004 Impreza WRX (SCCA DS 519)
2000 Saturn SL
Old 02-24-2005, 10:28 PM
P10DET's Avatar
P10DET P10DET is offline
Uh, I don't think so Tim....
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 02-28-2005, 12:55 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
it is a RACE car engine for a reason, the car weighs around 1200 lbs, and can make use of the 240hp high rpm engine. a light street car, roughly double that weight loses the advantage that the engine was designed for.
it would be fun in a stripped out light street type car, but nothing that would be on the street as a daily.
hello, i am Dan
No more project cars. I wonder how long that will last...
