93 Blazer
I have a 93 blazer that ran, but now it won't start. I changed the plugs, distributor cap, rotor, and fuel filter. It ran for a few days and then quit. It turns over but she won't start. Let it sit for the night and it started, ran it for awhile and it quit, won't start. I then changed map sensor, and pick-up coil. It will start and run for awhile then quit. I need some suggestions!
Re: 93 Blazer
Re: 93 Blazer
yea definately sounds fuel related to me. Try spraying some starter fluid into your injector and see if it starts up without sitting overnight. If it does than that will back you up that it is fuel related.
Not all starting problems have to be electrical. Keep that in mind next time before you begin throwing parts at it. Make sure to properly diagnose before wasting money. |
Re: 93 Blazer
Yip, check fuel pressure and also do you have the TBI or CPI 4.3l?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: 93 Blazer
Re: Re: 93 Blazer
Re: 93 Blazer
As stated above, check your fuel pressure, also pull your upper plenum and check the CPI/Nut kit..
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
After you check fuel pressure and plenum, if theylook OK, check your firing. My 93 S-10 Blazer just had the ignition module (in distributor) and coil replaced. Had same startup issues. Sometimes would run, other times would not. Got worse and worse til it would not run at all. But yes, check the fuel pressure first. As these guys will tell you, it has to have a fair amount, (I think 55+lbs) just to START.
Re: Re: Re: 93 Blazer
Re: 93 Blazer
I have a 93 vortex 4.3 an I'm also having the same problem...fuel pressure is good I spray starting fluid in it an it will start an run good till startin fluid burns out then it will die an won't start unless I spray it again I'm gonna try changing fuel presser reg an see if that will help
