Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 02-17-2005, 11:26 AM
Skaught77 Skaught77 is offline
Removing Front Passenger Seat - Easy?
I need to pack my truck inside and out, and I was wondering how easy it is to remove the fron passenger seat. That would give me some much needed space. Does it pop or, or is it more complicated than that?
Thanks,
Scott
Old 02-17-2005, 02:17 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: Removing Front Passenger Seat - Easy?
4 bolts, nothing to it. Pretty darn obvious...
Old 02-17-2005, 09:45 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
If you remove the drivers seat, make sure and disconnect the wire attached underneath so you don't yank it out.
Xterra4x4.com and the Xterra Offroad Webring
Old 03-17-2005, 12:26 AM
chubbybubba1 chubbybubba1 is offline
Talking Re: Removing Front Passenger Seat - Easy?
You might need a metric pnuematic torque wrench to remove the four bolts.
Old 03-17-2005, 09:40 AM
How's that? They're not torqued that tight.
And what's a metric pneumatic torque wrench? Does it measure torque in newton-meters, and specify air pressure in kilograms per square meter?
Old 03-20-2005, 08:29 PM
markplace's Avatar
markplace markplace is offline
ORX, you're exceptionally surly today. What I want to know is if you need both the right and left hand models for both sides of the seat.
Put some water on it!
Old 03-21-2005, 09:52 PM
XTerra Guy
I know the earlier seats are interchangeable, although the side handles will be harder to use. One member in our club did it pretty regularly to reduce the inevitable flattening on the cushions.
