Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-17-2005, 09:38 AM
Viriato Viriato is offline
Question No Heat
My car is a Grand Cherokee Limited 1996.
I don't what happen with my car. The AC unit working perfect but the heater not. i am open to any information o Tip(s). What i can do.
Thank you to all
Old 02-17-2005, 11:37 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: No Heat
does the blower run when in the HEATER position?
check the HVAC codes, I believe you push the recirc and AC button at the same time. and it should display the code(s).
Old 02-17-2005, 11:55 AM
mx52nv's Avatar
mx52nv mx52nv is offline
Re: No Heat
may be low on coolant as well. a low coolant level will make you blow cool air because there is not enough warm coolant to properly circulate through the system. and yes, you can have a very low level and still not overheat the engine. especially in the winter.
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
