Old 02-17-2005, 08:37 AM
leonhayle leonhayle is offline
'94 Cavalier flashers
I have heard a '94 Cavalier has two (2) flashers. One for the turn and one for the hazzard. I found the one for the hazzard, but not the turn. Is this true? If so, where is the turn flasher located. Reason: The hazzard (four ways) work. The turn signals don't. I have just installed a new turn signal switch, (after being told by the person who gave me the car that he had to replace it twice). Still no turn signals. Can anyone offer any help?
Thanks,
Leon Hayle
er son de bragh Albainn
Old 02-17-2005, 12:55 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Re: '94 Cavalier flashers
Do the arrow lights come on (flash or not) when you hit the turn signal switch? I know if one bulb is out they will come on but not flash, so if you are having to flash it yourself with the switch than it's probably a bulb. I know the flasher is a pain to get to.
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 02-17-2005, 06:26 PM
With the four ways, all the lights, interior and exterior work. With the directionals, nothing works.
Leon
Old 02-18-2005, 12:22 AM
cavalierman93 cavalierman93 is offline
The turn signal flasher is kind of up under the dash. Remove the trim by the steering column and lay down on the seat and look up between the steering column and the dash. Its mounted up there on the left as you look up.
Old 02-18-2005, 07:03 AM
Thanks.
Leon
Old 02-19-2005, 10:53 PM
noshun's Avatar
noshun noshun is offline
Originally Posted by leonhayle
Thanks.
Leon
I'd say something is amiss if the prev owner changed the switch twice and then you have and it's causing nothing else to work! I'd say that the wires are shorting. Check them out for missing insulation! You can just wrap them in insulation tape if so!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
