1995 Ford Escort Stalls after warming up
I have a 1995 Escort 1.9L Engine. The car runs fine until it warms up The car just will not idle right once it warms up. The rpms drop off and the car stalls out. As long as your foot stays on the gas the car runs great. If you stop at a light or stop sign I have to slip the car into neutral, with the break on of course, and keep my foot on the gas to keep it from stalling out when the rpms drop.
I have replaced the spark plugs, Spark plug wires, air filter, fuel filter, PCV Valve and filter. The engine light is not on so no codes to go by. Any ideas or suggestions would be appreciated. At my wits on trying to figure out whats wrong
Re: 1995 Ford Escort Stalls after warming up
It is a free service and they will tell you if you have any emission sensor issues. From your description, the problem sounds as if it is fuel delivery related, based on the problem becoming apparent only during 'closed loop' operation. However, the computer read-out will give you a starting point.
Alvin A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED. |
Autozone will not read the codes unless the Engine Light is on. I was told the engine light would only come on if a sensor triggered it.
Does your engine have the PCV valve located in the top of the valve cover? Is it a Mult-port fuel injection?
Re: Re: 1995 Ford Escort Stalls after warming up
Possibly a bad/going fuel pressure regulator on his fuel rail, or fuel filter? Maybe as far as pump or strainer? |
Re: Re: Re: 1995 Ford Escort Stalls after warming up
a. Remove the air cleaner, do not detach vacuum hoses and check to see if they in good shape, not cracked, and not leaking vacuum. b. Turn the air cleaner up side down and look at the vacuum motor door it should be 'OPEN' If it isn't it may be binding or sticking. Try to move it by hand, lubricate and work it until it moves freely. c. Start the engine and see if the door moves. If it does, shut off the engine and the door should move within a couple of minutes. If everything looks good. We will move on to the next step..... The Idle speed control (ISC).
Already replaced the Fuel Filter but will look into the Fuel Pressure Regulator and the Pump and strainer..waiting for a day when it is not snowing out
I have the same problem
I got exactly the same problem on my 1995 1.9L escort.
I tried replacing the IAC valve and it didn't help. I also cleaned up the throttle body and IAS bypass and it did nothing. Now, a garageman told me I must replace the wiring, but i'm almost sure it won't work. Keep me aware if you fix the problem. |
Same problem here too
I'm also having the same problem on my '01 Escort. Only difference is i have a service engine light on. I'm going to get the light checked tomorrow. Maybe it can give you an idea what to look at.
I would have a shop check the pump pressure to see if it's in spec.
Also the O2 sensor might be a good place to look as when it goes to closed loop this is computer uses to adjust the fuel injectors. Also, as previously mentioned check ALL the vacum lines under the hood as they get brittle over time and can leak. False air will cause a crappy/no idle every time. |
fixed...for now
I took my '01 to the dealer with that problem. (have family who works there) On mine it was the IAC valve. I have a temporary used one on there right now. i have to order a new one. Within five minutes mine was running fine. I work about an hour from where i live and i didn't have any problems on the drive.
Re: Re: Re: Re: 1995 Ford Escort Stalls after warming up
1999 Escort SE 2.0 ltr sohc, 5 speed - old one 1999 Escort SE 2.0 ltr sohc, auto - new one 2002 Dodge Grand Caravan sport 3.3, auto located in beautiful New England. "You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks |
Re: Re: Re: Re: Re: 1995 Ford Escort Stalls after warming up
Re: Re: Re: Re: Re: Re: 1995 Ford Escort Stalls after warming up
