Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-17-2005, 04:01 AM
gusti gusti is offline
Reduced airflow from center outlets 1999 model
Hi. I have this problem with my Cherokee. Does anyone know how to fix it. I have found out that there is a bullitin out TSB 240799 but I cant find it on the internet. Best regards Gusti
Old 02-17-2005, 04:46 AM
Bob D. Bob D. is offline
You're in luck, no disassembly required.
240799 - REDUCED AIRFLOW FROM CENTER OUTLETS
Date: 04/30/99
Model year(s): 1999
Description: Reduced airflow from center outlets.
Details: The heater A/C housing on these vehicles is sealed with a foam seal at the instrument panel. This seal can become loose or out of position. If this occurs, an air leak will be present in this location. This will result in reduced airflow from these outlets, be sure to check this seal. This can be accomplished by removing the center outlets and reaching into the opening with your hand. This seal can usually be repositioned without disassembly of the instrument panel.
Old 02-17-2005, 04:54 AM
Re: Reduced airflow from center outlets 1999 model
Thank you will try that
