Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 02-17-2005, 01:22 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
shift linkage pin, no more problems, easy solution.
just pulled my friends B16 and I always dread pulling a honda cuz of that pin holding the shift rod to the tranny, my freind gave me a good idea as I was crawling under herre with the punch and hammer. "palm-nailer" if you dont know what it is its a small air tool that fits in your palm and theres a sleeve you put the head of the nail in and then when you push it down the pressure of the nail activates it and its like an air hammer and just pounds the nail in.
a solid rod would work better but I just used a drill bit where the smoothe end was the right diameter and threw the pointed end into the sleeve, positioned it to the pin, gave it a little push and POP, knocked it a third of the way out with first pop, wear goggles though cuz the bit went flying. put it bakc in and pushed and it popped it maybe 4 times and it was out, tok like 10 seconds and it was out, I had tried with the punch for about 2 minutes and couldnt get it, this is the first time ive EVER goit the linkage of under the car, Ive always lifted the car HIGH and pulled the engine/tranny with the shift rod connected still anfd took it off out of the car.
side note Im now the owner of a B16 long block(but whatever broke loose ripped a hole in the pabn and tore out 4 oil pan bolts in the process so a rods broke most likeely and who knows what it did to the block, but the heads good and Ive got 2 non vtec blocks lying around here...
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 02-17-2005, 01:29 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: shift linkage pin, no more problems, easy solution.
So the thing's called a Palm-Nailer? I'm going to have to check this thing out. I've helped my friend with tons of swaps and it's always been a time consuming problem. Great tip.
Old 02-17-2005, 02:20 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
i thought people knew about this already?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 02-17-2005, 03:47 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i just used a small gear puller
Team Lonely Drivers
Old 02-18-2005, 02:20 AM
94tegRS's Avatar
Re: Re: shift linkage pin, no more problems, easy solution.
I had a puller and the canter bolt was the right diameter but I had nothing for the claws to grab on to pull against.
I never heard of using a palm nailer..
and yep, plam nailer, borrowing one evry swap I do from now on.
current
history:
Old 02-18-2005, 02:40 AM
i jsut put a cresent wrench on top of it to grab onto
Team Lonely Drivers
Old 02-18-2005, 01:50 PM
94tegRS's Avatar
you mean like how theres a hole at the end of the handle on the cresent, the hooks grab that and the pin comes thorugh the center?
took me a second to think of it that way, at first I as thinking how thre hell would you fgrab onto that pin, especially with a cresent. but then it hit me.
current
history:
Old 02-19-2005, 10:34 PM
thats not the way i had it. my cresent wrench would sit flush with the shift linkage so the gear puller hooked on the 2 sides of hte handle and because the cresent wrench didnt sit flat, there is a space so it just pushed it loose. kinda bent my cresent wrench though
Team Lonely Drivers
