Old 02-16-2005, 10:34 PM
LittlePretty09 LittlePretty09 is offline
Angry 91 Accord Will Not Start
Has Anyone Seen A 91 Accord Trying To Turn Over But Wont Start At All? I Have Replaced The Fuel Pump, Relay, Filter, Distributor Cap, Rotor, Plugs, And Wires. The Motor Has Compression, Spark, And Correct Fuel Pressure At The Rail. I Have Tried Everything But No Luck. The Car Originally Died Outside In Very Cold Weather But Now The Car Has Been Inside A Buliding For The Past Month With No Change. When The Car First Died I Replaced The Fuel Pump And It Ran For About 10 Miles Then Died. Now It Is Back To Square One With No Start At All. What The Hell Is Wrong Here?? Any Help Would Be Appreciated.
Old 02-16-2005, 11:06 PM
mpumas mpumas is offline
Re: 91 Accord Will Not Start
Possible fuel injectors/fuel to the cylinders. The injectors include a resistor connected to the main relay and the ECU provides a ground to operate the injector. Possible distributor problems in the sensors for TDC, crank angle or cylinder. Do you have any stored Engine check codes?
Old 02-17-2005, 07:18 AM
AccordCodger AccordCodger is offline
SOunds like a classic case of a main relay gone bad.
Old 02-17-2005, 10:24 AM
Ehscrewdude Ehscrewdude is offline
Send a message via AIM to Ehscrewdude
except for the fact that she said she replaced it... It'd be kinda wierd to have 2 bad relays on one car...
Old 02-17-2005, 10:32 AM
94hondaacc 94hondaacc is offline
Unless The Computer Is Fried.
Old 02-17-2005, 10:37 AM
quote]except for the fact that he said he replaced it... It'd be kinda wierd to have 2 bad relays on one car...[/quote]
Yeah - if that's the "relay" he's referring to. And if it was a new (not a junkyard) relay.
Old 02-17-2005, 11:10 AM
If the main relay was bad, he would not have spark. Me thinks the fuel injectors are not firing or not getting power.
Old 02-17-2005, 03:00 PM
First Of All Guys...im A Girl...lol....second It Isnt The Fuel Relay Because I Did Replace That...we Did Suspect The Whole Distributor Was Bad...the Engine Is Getting Fuel But No Start And It Is Really Frustrating
Old 02-17-2005, 04:52 PM
Deadhead's Avatar
Deadhead Deadhead is offline
what about fuel pressure? is there too much? too little?
1986 Honda Accord LX-i 5 spd
Completely stock... but i like it anyway, it's got a strong e-brake
www.cheesemit.us
http://www.cardomain.com/ride/862348/1
So y'are Ashlee!
Well, if you've checked that you have spark & fuel getting to the motor, and it doesn't even COUGH --- but wait -- what did you mean by "trying to turn over?"
Old 02-17-2005, 05:43 PM
Re: Re: 91 Accord Will Not Start
i dont have any codes and the cylinders are getting fuel
Old 02-17-2005, 05:46 PM
Yeah - if that's the "relay" he's referring to. And if it was a new (not a junkyard) relay.[/quote]
the relay was new and im talkin about the main fuel relay
Old 02-18-2005, 07:34 AM
Gaffertape Gaffertape is offline
Possibly the igniter (within the distributor). Mine went and it caused the car to stall out randomly and it wouldn't restart for sometime. Worth a shot.
GAFF
Old 02-20-2005, 07:52 PM
therealrayman's Avatar
therealrayman therealrayman is offline
Send a message via AIM to therealrayman Send a message via Yahoo to therealrayman
if the engine still turns over but doesn't start (and the starter still sounds okay) then it might be your distributor. My friends civic had the same problem. Try holding the key turned and giving it some gas over and over, might flood the engine, but my accord took like 5 minutes to start when its distributor was bad. If you get it started, letme know if the idling is erratic.
Old 02-21-2005, 07:01 PM
when i replaced the fuel pump the car ran.....i drove 3/4 of the way home. when i was moving it was fine but once i hit a red light or stop sign it was going crazy...the engine was sputtering and the rpm's where all over the place....at the last red light it did the sputter and then it died completely...that is where i have been for the past month and no one knows whats up....i am waiting for a distributor from my friend and we will see where that takes us....if it doesnt work im gonna die
