Old 02-16-2005, 10:22 PM
quikmatt5 quikmatt5 is offline
1988 Escort stalls and studders
Hopefully someone can help me, i have been dealing with this for almost 3 months and i cant figure it out. When i first bout the car i changed the spark plugs and the wires, when i went to take out the spark plugs two of them were stuck as i was trying to remove them they ends of them broke off and may have fell in the engine. but the car ran fine so i didnt worrie about them. about 2 months later it started stalling at idle or when i would come to a stop and would studder or choke on take off.
i thought it would be the PCV valve but i cant find out where it is located or if this model even has one..
please help me..Thanks
Matt
Old 02-17-2005, 09:50 AM
A. Souphound A. Souphound is offline
Re: 1988 Escort stalls and studders
Matt
Matt,
What size engine do you have, and is it a CFI or Multi-port injection system?
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 02-17-2005, 10:18 PM
its a 1.9L EFI
Old 02-18-2005, 12:38 PM
its a 1.9L EFI
Matt,
If your engine is a multi-port fuel injection the PCV valve is located on top of the valve cover. If, it's a CFI (Central Fuel Injected) it has a orfice type system. Identified by a round metal air filter housing.
Since you have changed the plugs and wires recently, did you change the distributor cap and rotor?
Sometime a fuel injector will stick and the engine will stumble. If you think that could be the problem I would put a can of fuel injector cleaner in the gas tank.
Alvin
