look frist i would like to say i start alot of thread and you guys never get tired of helping me thanks for that ........
but anyway i found a 1st Gen, Engine + Cable Type Transmission + ECU B16A1 for 1500 dollars....... but a 2nd Gen, Engine + 5 Speed Trans (Hydraulic) + ECU b16a is $2100 and a 3rd Gen, Engine + 5 Speed Trans (Hydraulic)+ ECU is $3000 what is the diffrents i only have enuff for the first gen but dose it matter do all the mod interchange is the trans. that much better that it cost so much more ? HELP |
Re: b16 whats it matter
I think the only thing that keeps people from the hydraulic setup is cause you would have to Mount a clutch master cyl, run lines for it and everything else, i think another reason for such a large price difference is availability. People who had these motors in their cars originally for the most part kept them cause they were happy with them and this made people who didn't have the motor in their car to put it in so therefore short supply high demand= Extra cost. Good luck with the swap man
thanks Scott82 but the old ones with the cable trans are the cheap ones so what you said cant be right but its all good but thanks just the same see what you can find out and goodluck on your swap to .the site i found is www.nippon-motors.com they have your motor on there check it out youll like it ....
thanks |
Thanks man, i was refering to the engine and tranny together the later model motors have less miles and there are not as many, i didn't know you were just alking about the trans itself. Sorry i couldn't help still learning alot though. take it easy
Get the 1st gen! It comes with the older cable trany that you need and a non-OBD ECU that you also need, and its cheaper!
www.passwordjdm.com has them for $1050!!! Go there! |
I have the 2nd gen with a cable tranny, I think its difference is 8-10 horse, if I had the chance, i'd go hydro tranny cause most the hydros come LSD...
I agree with the greatness of the 2nd gen sometimes comming with an LSD tranny, but I dunno if that and the extra 10hp justifies the $1000 price difference between the two. All the same, some 1st gens are available with an LSD if you shop around and know the right people.
![]() Its really your call, the 2nd gens have slightly better cams (ie: 2 or so HP) and a considerably better intake manifold wich is most likley where the power difference would be. |
