Old 02-16-2005, 10:15 PM
88ReX 88ReX is offline
Whats the best way to pull the engine?
Welp my cousin finally managed to spin a rod bearing in his Z. We are looking at rebuilding the motor with a 383 stroker kit so I have a couple questions.
1) Whats the best way to pull the engine, as in, should we remove the radiator/rad support, everything in front of the engine for maximum room?
2) What kind of machine work needs to be done on the block for the 383 stroker kit?
3) Assuming he goes with higher compression pistons, what's the highest compression you can run on pump gas (91) without detonation?
4) Will the ECM have to be modified/replaced for all of this or would a dyno tune be enough?
5) Anything else I need to know about the stroker kit?
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 02-16-2005, 10:29 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Whats the best way to pull the engine?
You have to remove the fans,radiator,water pump,power steering lines, y-pipe, intake manifold,steering linkage, torque converter bolts, and ofcourse motor mounts. Then you hoist pull forward (making sure the tranny is supported with a jack.) and twist to a 45 degree angle. You will need to take out the hood strut bolts to get the hood open enough. You will need to have the engine hot tanked and re-bored to 383 specs. Compression will depend strongly on what cam you decide you want to use and head porting stage. His car has a PCM not ECM and it can still be used but will need to be programmed to work with his mods. Is he planning to use a power adder as well and how much power is he looking for?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-16-2005, 10:32 PM
FormulaLT1's Avatar
Fight the powwa!!!
Oh you need to remove the A/C compressor lines and brake master cylinder vacuum hose as well.
Old 02-16-2005, 10:41 PM
Thanks for all the info, I have pulled 350's before on older trucks but not a newer one with limited front end room.
He's looking for 350-400whp which I think is easily achievable with this setup and staying n/a. Is this good for mid/low 12s?
Would the heads need to be hot tanked? Do I need to disassemble the valvetrain before I have them hot tanked?
Old 02-16-2005, 10:45 PM
FormulaLT1's Avatar
Fight the powwa!!!
The 4th Gen F-bodys engine were loaded from the bottom and are behind the cowl so its a little more difficult than the typical 350 removal. Yes get the heads hot tanked and yes disassemble and your going to be installing news head parts anyway and yes 400 horse is very easy to achieve and he should be running mid 12's with that set up. Good luck to you guys its a bitch but I did my engine in 3 days with a friend only helping me one day.
Old 02-17-2005, 07:19 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
4th gens cant come out through the top. no room...
*Better power-to-weight ratio than a C6 corvette*
Old 02-17-2005, 07:21 PM
FormulaLT1's Avatar
Fight the powwa!!!
Well then I must be a magician pulling a lt1 out of a hat cause I did it and its the method explained in Haynes and chliton.
John
Old 02-17-2005, 07:31 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
350 block bored .030 over with a 3.75" stroke = 383
Old 02-17-2005, 07:33 PM
Re: Re: Whats the best way to pull the engine?
John
ive been miss-informed...
Old 02-17-2005, 09:04 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
there isnt any such thing as a best way 2 remove the engine out of a camaro. it sucks! if u have the luctury of owning a lift it may make it better but it still sucks!!
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 02-17-2005, 09:39 PM
John
Lol, I hope to be a magician someday too!
Maybe I am too young but I still enjoy working on cars of all kind so even though it might be a challenge it still feels all the better after I kick its ass. :22yikes:
Old 02-18-2005, 12:14 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
i've also heard about lifting the body, leaving the k-member and all on the ground...
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 02-18-2005, 12:24 AM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Re: Re: Whats the best way to pull the engine?
Its not easy but with some time and patients you'll get it done. and as for taking it out the bottom I have read how you have to do this without the use of a lift and not only does it require taking the tranny out as well but it seems more time consuming and dangerous to me but do what you feel more comfortable with.
John
