Old 02-16-2005, 10:10 PM
Scott82 Scott82 is offline
Unhappy Is this prob what i think it is?
I have the 89 CRX HF as people should know by now and i am doing the motor swap cause i think that my HF has just played out. I am getting water shooting out of my coolant res. i have changed hoses thermo radiator cap and everything else i can think of to correct. So my question Do i have a blown Head gasket. I am not getting water and oil to mix but it seems like i am getting exaust pressure into my coolant system causeing it to build up too much pressure and shoot it out the coolant res. Anyone run across this before?
Old 02-16-2005, 11:15 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Is this prob what i think it is?
Very possible, there is a test for this, but I can't remember what it is.... I'll try tommorrow
Old 02-17-2005, 12:05 AM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
are u blowin water out the tail pipe...n does ur coolant seem like it magically disappears? if it is blowin it right outta the overflow then aint to much left for it to b....
Old 02-17-2005, 12:07 AM
Yes Exactly. where is it going the only reason i think it is all going out the res is because when i park i make a puddle and that is where it is coming from(the cool. res.)
Old 02-17-2005, 12:21 AM
travagliante's Avatar
travagliante travagliante is offline
run a compression/leakdown test. Doesnt sound like a blown headgasket to me because nothing is mixing? oil--coolant....
Is it burning smoke?
Id first check to see if there is a crack in your radiator or coolant resivor, or maybe even some hoses?
Old 02-17-2005, 12:26 AM
I have replaced every hose that carries coolant, changes water pump, thermo, readiator cap, and the radiator is only 6 mo. old I did a compression test thru the spark plug holes and it held fine. But i put a pressure test on the radiator i get almost 80 PSI without a pressure release and the water is spewing from the cool. res.
Old 02-17-2005, 12:27 AM
no smoke
Old 02-21-2005, 10:06 AM
well it sounds like u know what it is jus take the resivoir out n check it, it has no screw holdin it down jus pull it out n look...
Old 02-21-2005, 10:37 AM
I know it's coming out of the res. it's under so much pressure that is is coming out around the top where the cap screws on and there are no cracks is the res. i am wondering if anyone has seen a blown head gasket do this, either way i am going with the motor swap but i am just curious to see what is causing this prob. for future refrence.
Old 02-21-2005, 11:28 AM
johnb16a2's Avatar
Maybe the cap is bad?
Old 02-21-2005, 11:46 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i would say bad radiator cap. does it overheat at all ?
Team Lonely Drivers
Old 02-21-2005, 02:28 PM
i have put two new radiator caps on both set at 13 psi.
Old 02-21-2005, 03:11 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Is it overheating? Generally for coolant to be shooting out of the resivor like that it is boiling, which is way to hot.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 02-21-2005, 03:37 PM
once all the water boils out it over heats but as long as there is water it does not over heat. and also during all this process when i am in 4th and 5th gears the heater inside isn't very warm except on take off and crusing about 55 in third.
Old 02-21-2005, 04:11 PM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
i'm willing to bet money it's
A) blown head gasket
B)cracked block
Take your radiator cap off. Crank your car.... IF water shoots out then it's a blown head gasket. if it doensn't then nothing is wrong you're just seeing things. you can email me or IM me i'll help get this solved
1989 honda civic hatch Standard model Gutted
(1650 lb)
Freshly rebuilt ZC
2.5 exhaust
(2) 10lb bottles of juice
75 wet shot
lightweight crank pully
ZC tranny W/ SI final
8lb flywheel
Dual force p.p.
ACT clutch
2.5" drop
cheap tires
cheap rims
projector headlights W/matching corners
20% tint
semi-flat black paint (hotrod black)
