Old 02-16-2005, 05:42 PM
kingpinn's Avatar
kingpinn kingpinn is offline
is this possible
can i pull off getting every thing i need to do a b16/b18/b20 swap
for around $1800
thanks
Old 02-16-2005, 06:19 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: is this possible
probably not
Old 02-16-2005, 08:14 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
If you know the right people yes.
If you dont know anyone than no.
Or it depends on the deals you get.
2002 Acura TL Type S
1991 Honda Crx Si
Old 02-16-2005, 08:20 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yes it is possible to get everything you need for 1800, i got all my parts for like 300 so saying the motor is roughly 1300. he should be able. now if you want good parts, thats a different story and also depends how complete is the swap
Team Lonely Drivers
Old 02-16-2005, 10:05 PM
kingpinn's Avatar
well guys i found this site www.nippon-motors.com/honda.htm for the 1gen set up for 1500 is that a good deal i think so because then i just need mounts and axels right
Old 02-17-2005, 12:17 AM
travagliante's Avatar
travagliante travagliante is offline
yeah but did you factor in the at least 150-300-for cheapo ebay mounts, 150-linkage, axles(teg ones) still should set you back about 50, plus i know before you put er all in you will want to change the timing belt! You also will need other misc parts (oil, coolant, tranny fluid,) Also you need the engine shipped if you cant pick it up.
But honestly yes you can do it easaly for under 1800 bucks. Im going back now to a 1.8L b16a... Here are my costs:
300-engine b16a (local needed top end stuff, no dizzy)
150-ys1 5spd tranny+ axles and int. shaft(from junkyard
150-ebay mounts
130-shiftlinkage
160-head gasket set and timing belt
25-distributor
140-pr3 ecu
Free-map sensor tps sensor,knock, iacv,and vtec sel.(pocketed!)
So my total cost is about $1100ish. Add up to see if im correct. YOu could always go with a b18a which can be easaly found in junkyards for about 150bucks and rebuild it!
Total cost
Old 02-17-2005, 11:13 PM
kingpinn's Avatar
what is the ys1 5spd tranny from
Old 02-18-2005, 03:45 PM
SiZ's Avatar
SiZ SiZ is offline
Should be.. Lots of shopping around and talking to people.
I payed less than $900usd. for my B16. Motor, tranny, ECU, linkage.
You just have to get to know people around you, even a few hours away..
