Old 02-16-2005, 04:17 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
non camaro idle problem
maybe some of you techies can help me out.. Cant find none in the c/k forum
my winter truck, a 1996 GMC 1500 w/ a 305 vortec SMPI auto trans..
Took the intake and MAF off to clean the throttlebody, started the truck and sprayed the TB til it was clean, sprayed the MAF with tb cleaner, and re-assembled..
Now it wont idle under 1000rpm.. when I start it, or when I put it into park, it will race up to 1500, than back down to 1000.. It still idles as smooth as it did before, and drives the same (other than the tranny shifting harder because of the high idle)
Could this be a fried MAF? ive never had a bad maf before.. Anyone know how to test it? Also, when I unhook the TPS, Nothing changes, it runs exactly the same w or w/o the TPS hooked up.. could this be a bad tps?
1991 Camaro Z28
Old 02-16-2005, 08:59 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: non camaro idle problem
Yes it could be MAF related and you cleaned it?
How?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-16-2005, 09:59 PM
DaMoNe6969's Avatar
the maf wires were very dirty so I sprayed it with throttlebody cleaner..
the engine light is on.. has been for awhile, Anywhere around here charges an arm and a leg to scan the codes..
I ordered a obd2 code reader off of e-bay.. Might just havto wait til I get it..
1991 Camaro Z28
Old 02-16-2005, 10:20 PM
FormulaLT1's Avatar
Fight the powwa!!!
I have heard and strongly agree not to touch those wires. They are extremely sensitive and I would never put chemicals on them. I would bet money you have a MAF code stored.
Old 02-16-2005, 10:28 PM
DaMoNe6969's Avatar
yeah I know your not supposed to touch them.. But people clean them with chemicals all the time.. Ether is a common choice, but Ive cleaned many MAF's with throttlebody cleaner.. But im startin to think I fried it too.. Ive checked EVERYTHING else
Do you know any ways to test the MAF??
1991 Camaro Z28
Old 02-16-2005, 10:37 PM
FormulaLT1's Avatar
Fight the powwa!!!
I read this method in my service manual but never tried it. It says if you tap on the flat part of the MAF while the engine engine is running. If it stumbles or stalls it is faulty.
Old 02-16-2005, 10:46 PM
DaMoNe6969's Avatar
hmm.. i'll give it a whirl, thanks
aside from the MAF, I pulled the TPS off today, and on the inside of the tps (where it slides on to the throttlebody lever) it was very loose, I could move it in and out quite a bit, and there was no resistance when i turned the tps, I could turn it all the way in one direction and it woulnt spring back.. arent they all spring loaded??
1991 Camaro Z28
Old 02-16-2005, 11:04 PM
FormulaLT1's Avatar
Fight the powwa!!!
Did it turn freely in clockwise and ounter clockwise directions?
Old 02-16-2005, 11:16 PM
DaMoNe6969's Avatar
well when I took it off it was fully counter clock-wise.. but I could turn it freely clockwise then back.. in total it would turn about 60 degree's
so yes, it turned freely clockwise and counterclockwise..
1991 Camaro Z28
Old 02-16-2005, 11:18 PM
FormulaLT1's Avatar
Fight the powwa!!!
Thats weird. They are not suppose to be able to move like that. May be something to look into but that would show up on the scan. Not worth guessing on til you scan it.
Old 02-16-2005, 11:19 PM
DaMoNe6969's Avatar
I figured it might also be the problem because there was absolutly no change in idle or driving with or without it hooked up..
I could unhook it while the truck was running and there would be no change
1991 Camaro Z28
Old 02-16-2005, 11:22 PM
DaMoNe6969's Avatar
I unscrewed it from the throttlebody but left it hooked up, and started the truck.. even if I shook it a little bit or tapped on it the idle would go crazy..
Ive adjusted and replaced TPS's on a few vehicles before and have never seen it do that.. But Ive never had much experience on 95-newer vehicles..
especially this Vortec..
1991 Camaro Z28
Old 02-16-2005, 11:59 PM
FormulaLT1's Avatar
Fight the powwa!!!
Those are non adjustable on those cars so it doesn't have adjustment screw but it isn't suppose to be lose either. It just may end up being your problem but I don't recommend cleaning your MAF either, to anyone
Old 02-17-2005, 12:21 AM
WeirdRich WeirdRich is offline
Send a message via AIM to WeirdRich Send a message via MSN to WeirdRich Send a message via Yahoo to WeirdRich
In an attempt to gain a little bit more knowledge, why can't you clean it? I understand that they are sensitive, but what makes them that touchy? Also, what are the signs of the MAF being bad. Is it going to be an obvious problem, or is it just going to rob power without you knowing it?
1994 Camaro Z28 Convertible 385
1981 Honda CB 750 Custom
Old 02-17-2005, 12:29 AM
FormulaLT1's Avatar
Fight the powwa!!!
MAF sensor wires are protected with a screen so as not to get touched and how it works is the thin wires are heated by voltage and the air that enters and passes the wires cool the wires lowing the voltage. The PCM measure the voltage remaing to see how much air is passing the wires and adjusts the injectors and IAC settings accoring to this. So imagine putting a flamable solvent on wires that get heated and second imagine rubbing super thin(line the size of a lite filament) with a rag. Not only can you make the wires thinner or run hotter throwing off the PCM. You can weaken them causing it to burn up or break later on.
