Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-16-2005, 03:55 PM
xdrgnqueenx xdrgnqueenx is offline
Send a message via AIM to xdrgnqueenx Send a message via Yahoo to xdrgnqueenx
Angry RE:my brake lights wont work
95 olds cutlass supreme se
i have had an ongoing problem with the brake lights.they wont work the upper one in the window works but the lower one dont work.the tail lights worktoo.im lost dont know what would cause that.can someone please help!!
Old 02-16-2005, 05:40 PM
shadyschnauzer shadyschnauzer is offline
Re: RE:my brake lights wont work
I had that same sort of problem a couple of years ago with my 94 cutlass, and I fiddled with the turn signal switch and that was the problem.Hope this helps. [email protected]
Old 02-19-2005, 10:14 PM
Manny_boy's Avatar
Manny_boy Manny_boy is offline
Exactly... your turn signal switch is the problem. The lower brake lights are routed through the turn signal switch, while your high mount brake light is not.
Old 02-21-2005, 10:19 AM
dhspring dhspring is offline
You need a new turn signal switch, this is notoriously bad in 94 Cutlasses, you have to replace the switch in the steering column, it cost about $75 and a dealer will charge you 200-300 to put it in, or do it yourself, you have to take off teh steering wheel to do this.
