Old 02-16-2005, 02:39 PM
JoshBarber JoshBarber is offline
Question Trouble Code
P0446
EVAP canister vent blocked.
I was told by the kid at AutoZone, that it's a common code for something related to the gas cap being loose, or filling the tank with the vehicle running. I don't remember doing that, and I rechecked the cap which seemed OK. He reset the Service light, and I'll have to wait and see if it returns. Any other suggestions? Anyone else have this code?
What was the fix?
Old 02-16-2005, 02:50 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Trouble Code
could be from a old cap needing replacement.
I would check the evap canister though and make sure it doesn't have any water in it.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-16-2005, 02:56 PM
Re: Re: Trouble Code
In my book, theres no photo of this. Can you explain where it is to me, and how I check it for water?
Old 02-16-2005, 02:57 PM
BlazerLT's Avatar
AF -Advisor
Re: Trouble Code
check the emmisions sticker in your engine compartment.
Old 02-16-2005, 02:58 PM
what am I checking it for? a location? or reading?
Old 02-16-2005, 03:16 PM
BlazerLT's Avatar
AF -Advisor
Re: Trouble Code
location
Old 02-16-2005, 03:23 PM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
Here is what AllData says on the P0446 code: May help you ....
Circuit Description
The VCM monitors the performance of the EVAP system by applying a predetermined level of vacuum to the EVAP system and monitors the vacuum decay rate. The VCM sets this DTC if the vacuum decay rate is greater than a predetermined value. The VCM monitors the amount of vacuum and the amount of pressure in the EVAP system by monitoring the Fuel Tank Pressure sensor. For this DTC the VCM turns ON both the EVAP Purge Valve and the EVAP Vent Valve when the Conditions for Running the DTC are met. This applies an engine vacuum to a closed EVAP system. The VCM turns OFF both the EVAP Purge Valve and the EVAP Vent Valve when the system reaches a correct amount of vacuum. The EVAP system should quickly RELEASE the vacuum in the EVAP system with the EVAP Purge Valve OFF and the EVAP Vent Valve OFF (open). This test indicates a blocked or restricted EVAP Vent path, if the EVAP system fails to release the vacuum quickly enough.
No active MAP sensor DTCs
No active TP sensor DTCs
No active VS sensor DTCs
No active O2 sensor DTCs
No active ECT sensor DTCs
No active IAT sensor DTCs
DTC P0125 not active
The fuel level is greater that 12.5% but less than 87%
The system voltage is between 10 and 17 volts
The ECT is between 4°C and 30°C (39°F to 86°F)
The IAT is between 4°C and 30°C (39°F to 86°F)
The cold start temperature difference (ECT minus IAT) is less than 1.5°C when the IAT is greater than the ECT or 8°C when the ECT is greater than the IAT
The BARO is greater than 72 kPa
The change in fuel tank vacuum is less than 0.6 in. of H2O, or the change in fuel level is less than 8%
The fuel tank vacuum level remains above a calibrated value for a specified number of seconds
Conditions for Setting the DTC
The VCM fails to detect a drop in the EVAP system vacuum over a calibrated number of seconds with the vent solenoid open.
Action Taken When the DTC Sets
The VCM illuminates the MIL during the first key cycle in which the DTC sets.
The VCM stores the conditions that were present when the DTC sets as a Freeze Frame and Fail Records data.
Conditions for Clearing the MIL/DTC
The Control Module turns OFF the MIL after 3 consecutive drive trips when the test has Run and Passed.
A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles (coolant temperature has risen 22°C (40°F) from the start-up coolant temperature and the engine coolant temperature is more than 70°C (158°F) during the same ignition cycle).
Use the scan tool Clear Information function.
Diagnostic Aids
Important: An accurate indication of fuel level is required for the VCM to properly Pass or Fail this DTC. Always diagnose fuel level sensor DTCs before performing this DTCs diagnostic table. Always check for fuel level sensor DTCs stored in History.
Check for the following conditions:
A loose, missing, damaged, incorrect or improperly installed fuel cap
Missing or damaged O-rings at EVAP canister fuel vapor and purge line fittings
A cracked or punctured EVAP canister
Incorrectly routed or damaged EVAP system purge and vapor lines
A damaged or disconnected EVAP purge line, vent hose or fuel tank vapor line
A stuck closed EVAP Vent Valve
A restricted or stuck closed fuel tank rollover valve
A poor connection at the VCM: Inspect the harness connectors for the following conditions:
Backed out terminals
Improper mating
Broken locks
Improperly formed or damaged terminals
poor terminal to wire connection
A damaged harness: Inspect the wiring harness to the EVAP vent solenoid, EVAP purge solenoid and the fuel tank pressure sensor for an intermittent, open or short circuit
A kinked, pinched or plugged EVAP purge, or fuel tank vapor line. Verify that the lines are not restricted
Reviewing the Fail Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
Test Description
Number(s) below refer to the step number(s) on the Diagnostic Table.
If the vacuum stored in the EVAP system is quickly released then an intermittent system restriction or failure of the EVAP Vent Valve or the EVAP Fuel Tank Pressure Sensor may have occurred.
Checking the vapor canister and the EVAP Vent Valve for restriction.
An EVAP Pressure sensor that does not correctly respond to pressure (or vacuum) will cause this DTC to set. The EVAP Pressure Sensor monitors a range from 7.5 in. H2O of pressure to - 17.5 in. H2O of pressure (vacuum). In order to test the EVAP Pressure sensor for pressure response SEAL the system with the scan tool and use the EVAP pressure/purge diagnostic cart to apply pressure to the system. Compare the pressure gauge (in. H2O) on the diagnostic cart to the EVAP Pressure sensor reading on the scan tool.
Old 02-17-2005, 07:40 AM
Re: Trouble Code
still havent located it yet.....although, Chevy dealer told me this is more common with having a spider nest or something similar inside the tube that runs to the canister. They said they've seen it in cars only a year or two old...I guess they climb in somehow and make a nest.
He reccommended removing it and sticking something in it to clean it out. Not sure what to think about this.
As I said...still trying to locate in under the hood.
Old 02-17-2005, 08:08 AM
located
reason I couldnt find it under the hood is because its not UNDER THE HOOD!
It's behind the rear left wheel quarter panel. I'll let everyone know what I come up with
