Engine choice?
Ok guys I need help. I can't figure out what swap to do. I'm going to buy a 4G4D (99% sure a DX). I have changed my mind so many times on which motor to do, from just an A6 ,to a DOHC ZC, to a mini me and back again.
Ok I have $2000 to spend. And a pretty good mechanic (yes thats you Sparsky). I'm retired from street racing but I don't like being as slow as dirt. |
Re: Engine choice?
dohc zc is a good choice. i prefer a sohc vtec to a zc.
Re: Engine choice?
zc will get you more power but the Si d16a6 motor has more aftermarket support (so i hear) - depends on if you're going to mod it in the future i guess. I have a d16a6 and i'm going to tell you to get a d16a6 because i have one and i like it
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles :: working on mechanical and cosmetic restoration ::
DOHC ZC
imo its a great motor
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
Re: Engine choice?
If your intention isn't to be fast, but have a little more than adequate power, you can just convert from DPFI to MPFI and run your basic I/H/E combo. That should be nice and comfortable as is and still have great gas mileage (not to mention have extra money to spend on other things). The DOHC ZC would be a good choice as well and since it's a direct replacement, there isn't anything special needed to complete the swap (other than converting to MPFI). You can modify the DOHC ZC the same as a D16A6 for the most part. It's just knowing which parts to mix and match between the USDM Si engine and USDM 89 Integra LS engine. Since you are working with a $2000 budget and you aren't exactly planning on racing it around, I'd consider swapping a B18A1 motor. In stock form, that should have more than enough HP/Torque to satisfy your need for more power. And, if you decide to modify later, you can go in so many directions with the LS motor.
Re: Engine choice?
ZC or Z6! Go with a Z if you're going to piss around with D series motors.
Re: Engine choice?
get a d16z6 and get a p28 ecu and your set
