Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 02-16-2005, 12:21 PM
EVOclipse EVOclipse is offline
Send a message via AIM to EVOclipse
Question Apex Seal?
Ok im looking at going RWD , anbd i found a nice 86 RX-7 with no rust and good body interior, its got AC and everything, just over a 120k, for only 700$ maybe a little less(prolby) only thing the guy said he was having problems is that it needs an apex seal or something. on the first rotor, i dunno shit about the rotary's yet so any help here would be appreciated. thanks
240sx, soon to be S13.5, future mods are wheels and hopefully paint and the rest of my conversion.
(96 eclipse RS 5-speed, magnaflow exhaust,chrome headers,cold air intake,denso iridium sparkplugs,new kumho tires )******EDIT totalled car now*******
Old 02-16-2005, 03:51 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: Apex Seal?
it will need a rebuilt, wich is in the 500-2000$ range depending on what is fucked inside, and what work you wanna do
Old 02-16-2005, 04:38 PM
Re: Apex Seal?
dunno like i said he said it was the apex seal ,but that the car runs fine he drove it about 20-30 miles to show it
Old 02-16-2005, 05:11 PM
D3rELiC's Avatar
Re: Re: Apex Seal?
i was lying, dont beleive me.
Old 02-16-2005, 05:34 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Apex Seal?
an apex seal is basically a more critical piston ring for the rotary engine.
RX-7 TII
Old 02-16-2005, 06:24 PM
Re: Apex Seal?
so its like a non expensive part(relativly) but a bitch to replace. so expensive if i had it done? thats what im kinda getting at?
Old 02-16-2005, 06:39 PM
D3rELiC's Avatar
Re: Re: Apex Seal?
lets say you do the work yourself
you'll have to take the engine out of the car
then open the engine, wich means a gasket and o-ring set to start off
$200
you'll have to buy the atkins cassette to know how to rebuilt your engine
$30
you'll also have to buy new apex seals
$200-250
you'll have to check if your seals are on spec, seals and groove
you also gotta hope the guy isnt raping the rotor housing while runing with a faulty seal, cuz that might kill the housing, wich cost $500 a piece, new
rotors can also be damaged by those kind of wears, wich is also $500 a piece.
a base rebuilt by someone knowing is stuff is no where below $1k
and in the $600 range to have the engine removed and installed
Old 02-16-2005, 10:13 PM
RevvRX-7's Avatar
RevvRX-7 RevvRX-7 is offline
Send a message via AIM to RevvRX-7 Send a message via MSN to RevvRX-7 Send a message via Yahoo to RevvRX-7
Since were talking about seals..where are the coolant seals located on the engine? Is there a diagram that points all this stuff out?
"Hand to hand. It is the basis of all combat. Only a fool trusts his life to a weapon."-Grey Fox -Gray fox (Metal Gear Solid)
"There is no good,there is no bad.Just perspective and opinion."-Squall Leonhart(Final Fantasy VIII)
"Love.. it is just an illusion which weakens and imprisons us."-me
Old 02-16-2005, 10:54 PM
D3rELiC's Avatar
Re: Apex Seal?
coolan seals ? you mean, the one for the waterjackets ? its the o-rings all arround the housings
