Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 02-16-2005, 09:37 AM
GETOUTHEWAY GETOUTHEWAY is offline
Angry Smoke And Loss Of Power!!! Is This
The Catalytic Converter?
I change my oil two days ago....It recently began to smoke! Fresh tune up, and everything. But I do hear a rattle sound as if a rock is in something under the truck. When I accelerate it gets louder! PLEASSSSSSSSSSSSSSSSSSSSSSSSSSSSSSEEEEEEEEEEEEE HEEEEEEEEEEEEEEEEEEELLLLLLLLLLLLLLLLPPPPPPPPPPPP
Thank you kindly!
Old 02-16-2005, 09:54 AM
Reels Reels is offline
Re: Smoke And Loss Of Power!!! Is This
Thank you kindly!
Check your fluid levels. Sounds like an oil problem.
Old 02-16-2005, 08:52 PM
2000CAYukon 2000CAYukon is offline
What color is the smoke? What Year? Engine?
//2000CAYukon
Old 02-17-2005, 07:50 AM
84fiero123's Avatar
84fiero123 84fiero123 is offline
if its the 93 blazer thats on your profile it could be anything, depending on milage, usage and a dozen other things, need more info.
get under the thing when its running, look DON'T TOUCH!, at the converter. if its turning red its bad. 3 options
1. remove converter and put test pipe in, will tell you if its bad but in most states that have emition standard not legal to run that way.
2. remove converter and have some one clean it out, or cut it open and clean it out and weld it back together, again not legal.
3. if you are sure it is the converter, and the only way to tell for sure is to use test pipe. replace converter, most emition equipment has at least a 10 year warrenty.
first off give us some more info
Old 02-17-2005, 02:26 PM
9yukon9 9yukon9 is offline
Send a message via AIM to 9yukon9
If you over filled the oil you may have blown a seal.
Old 02-17-2005, 02:28 PM
That will make smoke and lose compression.
Old 02-17-2005, 07:17 PM
Mr. Peabody Mr. Peabody is offline
Re: Re: Smoke And Loss Of Power!!! Is This
[quote=84fiero123]if its the 93 blazer thats on your profile it could be anything, depending on milage, usage and a dozen other things, need more info.
get under the thing when its running, look DON'T TOUCH!, at the converter. if its turning red its bad. 3 options"
DON'T DO THAT!!! Sheesh nothing could be dumber than to get under the vehicle when it running. Let it run for a while, turn the f**ker off. block it so it won't roll and then slide under it.
Old 02-18-2005, 06:10 AM
84fiero123's Avatar
Re: Re: Re: Smoke And Loss Of Power!!! Is This
[quote=Mr. Peabody]
forgive me, had a brain fart ment to say look under, your right never get under a running truck unless someone is in it in the drivers seat.
technology is great when it works
but one big pain in the ass when it doesn't
Detroit Iron Rules, all the rest are just toys!
