Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 02-16-2005, 09:58 AM
danbgt danbgt is offline
ABS and brake lights
I have a 91 B250 conversion van (RoadTrek). The brake lights have stopped working and the ABS warning light has come on. Not sure if both happened at the same time or not. Is there a connection between the ABS light and the brake lights? The brakes are working fine and I am getting power to the brake light switch. Any help would be greatly appreciated.
Old 03-10-2005, 04:23 PM
asif420 asif420 is offline
Send a message via Yahoo to asif420
Re: ABS and brake lights
abs warning light and brake light should be seperate systems. If you have power at and after switch check for power at light,bad bulb, bad ground at light if no power at light with brake on look for a broken or bad wire.
