Old 02-16-2005, 08:43 AM
ElmerFudd's Avatar
ElmerFudd ElmerFudd is offline
Send a message via MSN to ElmerFudd
Wiring or ECU problem
It seems that now and again everytime i pull the key from the ignition my blower fan will still run... my running headlights will remain on.. and when i open the door the car will beep indicating that the key is left in the ignition when it is really in my hand... i'm wonder if one of the other units around the ECU is an Ignition unit.. and should it be replaced? Or maybe it is the actual ignition that is creating the problem.
Thanks for your time!
Old 02-16-2005, 09:33 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: Wiring or ECU problem
please put your car in your sig! make, model, year, trans, and any mods.
Old 02-16-2005, 10:08 AM
ElmerFudd's Avatar
Have a Sig.
93' Eagle Talon ESI 2.0L DOHC FWD w/ K&N
20% Car 80% Driver!
Old 02-16-2005, 01:27 PM
musicman181 musicman181 is offline
Re: Re: Wiring or ECU problem
excuse, my newbiness. but what is K&N
civics are for suckas
95' eclipse gst
stock turbo
new C.A.I.
programmed ecu
2.0 DOHC manual
greddy bov
im workin on it. slowly but showly
Old 02-16-2005, 01:32 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
a K&N intake filter.
elmerfudd: i think your ignition switch is bad. the headlights staying on and stuff wouldn't have anything to do with the ecu as it controls the engine. try replacing your ignition switch and that should fix your problem.
95 Talon TSI AWD
97 Eclipse GST
Old 02-16-2005, 09:29 PM
SLoe's Avatar
SLoe SLoe is offline
You should test the ignition switch continuity before you just replace it. Go buy a cheap multi-meter, and a haynes repair manual and you might save your self some money in the long run.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 02-17-2005, 07:21 AM
ElmerFudd's Avatar
The ignition switch eh! Sorry for my ignorance... but what exactly is the ignition switch? is that the actual ignition where the key goes in? or is there more to it? Thanks for your replies!
20% Car 80% Driver!
Old 02-17-2005, 12:32 PM
that's basically what it is. it's a unit that controls power to almost anything in the car by turning the key to different points.
95 Talon TSI AWD
97 Eclipse GST
Old 02-17-2005, 03:27 PM
SLoe's Avatar
Do your self a favor and go get the repair manual, it's only $20 and it even has pictures. It will tell you almost anything you want to know.
Old 02-17-2005, 03:38 PM
Chilton makes a great manual for our cars. I always seem to be using it for some thing or another.
95 Talon TSI AWD
97 Eclipse GST
