Old 02-16-2005, 02:35 AM
hootymo's Avatar
hootymo hootymo is offline
Send a message via AIM to hootymo
newbie vibration question
hi everybody! i am new here, i just got a 2000 blazer lt 4x4. i am noticing some very subtle but annoying vibration that sounds like it is coming from the rear end, however i can feel it a little bit in the steering wheel too. it only starts when i hit 40mph and go from there. the weird part is, its worse at 40mph then gets less noticeable as i go faster. there is no moaning or howling like a wheel bearing usually does, just a steady vibration whose sound kinda resonates through the whole truck, like a very low-pitched humm. could this still be front wheel bearings? i replaced the driveshaft rear u-joint but not the front one, could this be a cause as well? any and all help would be greatly appreciated, this is annoying me because i thought these trucks were supposed to have really smooth rides. thanks!
Old 02-16-2005, 02:36 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: newbie vibration question
hmmmm...
First thing I would have said was rear u-joint.
Odd that that wasn't the problem.
Could be the front one. or the driveshaft is out of balance.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-16-2005, 02:38 AM
hootymo's Avatar
how hard is it for the home mechanic to change a front u joint? do i need any special tools or anything?
Old 02-16-2005, 02:49 AM
BlazerLT's Avatar
AF -Advisor
The front one is a pain and you will need a torch to melt the nylon asembly to get it out.
I would spend the 100 bucks and have a shop do it. They have all the tools.
Old 02-16-2005, 03:01 AM
hootymo's Avatar
hmm ok, but you are definitely thinking front u joint? anything else that can cause vibration? cuz i know the driveshaft is balanced correctly. thanks for the quick replies
Old 02-16-2005, 03:05 AM
BlazerLT's Avatar
AF -Advisor
Before anything I would have the tires checked out for balance and for proper pressure.
32psi cold.
Old 02-16-2005, 03:07 AM
hootymo's Avatar
oh yea i forgot to mention that, i just had new tires put on and balanced and a front end alignment done. it definitely feels different than tires out of balance too, its a different kind of vibration. i just wish i could describe it better or you could take a ride in my truck
Old 02-16-2005, 03:11 AM
BlazerLT's Avatar
AF -Advisor
I would have the front u-joint checked before you replace it.
If it moves freely, it is fine.
Old 02-16-2005, 05:39 AM
ricksza's Avatar
ricksza ricksza is offline
If the vibration just started after having the tires put on, suspect the tires first. Move the rear tires to the front and see if the vibration changes. Possible bad tire, the balance is off, or a rim is bent.
Old 02-17-2005, 10:47 PM
hootymo's Avatar
well we changed the u joints and still doing it, any more suggestions? what kind of rear wheel bearings does the 2000 blazer have, hub and bearings or can the bearing itself be replaced?
Old 02-18-2005, 01:40 AM
Officer Redneck's Avatar
Officer Redneck Officer Redneck is offline
Send a message via MSN to Officer Redneck
Sounds like a weight may have fallen off a rim. My uncle owns a tire shop and it's a common problem.
2003 Honda Element EX
2002 Kia Spectra (can't "Improve" or wife will kill me)
1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot)
" Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White"
http://www.myspace.com/officer_redneck
Old 02-18-2005, 02:45 AM
hootymo's Avatar
tires have been balanced twice already, problem hasnt gone away. definitely not tires... any other ideas? how easy is it to change rear wheel bearings?
Old 02-23-2005, 08:30 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
I have the same problem. My moaning noise starts at 50mph now. I'm thinking it's either wheel weights or bad bearing. I' doin some research on the rear bearing now.
Old 02-23-2005, 10:05 PM
hootymo's Avatar
awesome let me know what you find out about the rear bearing, i cant possibly find anything else wrong with this truck... could it be the front u-joint on the rear driveshaft too though? because i do get a clunk when i put the truck from reverse to drive, and i have seen people talking about that on here when they have bad u joints that it makes that sound... help!!
Old 02-24-2005, 12:15 AM
chcknugget's Avatar
You might want to look into a bent axle if you've been in any sort of accident. I think I get slight road noise from the front passenger side of my jimmy from that.
I've seen documents where people say park to reverse clunking is normal on 4wd vehicles, I've also read that it is not normal. Go figure.
I'm planning on going to a shop and have them look at it. I just don't want them to poke, play, and charge me if nothing gets fixed.
