oxygen sensors
Blazer 108k miles. Should oxy sensors be changed even if there are NO problems with the vehicle just as a prevenative maintance program? How many are there on a Blazer? Thanks.
Over time the element in the front oxygen sensor becomes less sensitive to oxygen in the exhaust, reducing how quickly it will adjust to change in exhaust. It's over all up to you, I would change it. The rear oxygen sensor monitors the effectiveness of the catylitic converter by comparing the front sensor readings to it's own. I don't change the rear one unless the SES light turns on.
Re: oxygen sensors
Thanks. So I take it there are two. What does SES
stand for? |
Re: oxygen sensors
What year do you have and yes, you should change them.
I changed mine and got a 3MPG increase. |
Re: oxygen sensors
Hold on, you don't know what year Blazer. '94 and older will have only one and it is pre-cat. I worked on a '96 two weeks ago and it had 4. One on each downpipe from the manifolds, a pre-cat and a post-cat.
Re: oxygen sensors
My 95 has a pre and post cat sensor.
Re: oxygen sensors
And there you go, there's 3 variations on Blazer's that GM has done. The '96 was a Jimmy but I fail to see if that would be a difference.
Re: oxygen sensors
97'
looks like there are 2 oxy sensors. 1 before the catalitic converter and 1 after. Is that it?
Re: oxygen sensors
There will be one also in the exhaust pipe coming down from each manifold too.
Thanks, for the info.
Re: oxygen sensors
Do you need to use GM O2 sensors or are aftermarket (like Bosch) OK ?
2005 Chevrolet Silverado 2500HD Ext cab |
Re: oxygen sensors
Bosch are completely fine.
Bosch actually designed GM's O2 system. |
Re: Re: oxygen sensors
Re: oxygen sensors
Should be part of a preventative maintenance.
How many miles and what year is yours?
1995 Factory Blazer Service Manual for sale, PM if interested. |
