Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 02-16-2005, 01:51 AM
GhostRyder Concept's Avatar
GhostRyder Concept GhostRyder Concept is offline
Send a message via AIM to GhostRyder Concept
GSR vs. F22a
Okay I looked around in this forum but nothing really answered my question. Just a bunch of dumb ass questions too yall. Ne wayz I got a F22a from my accord that is worth nothing to sell I figured I would pull it and rebuild and put it in a Del Sol ( not a bad idea) I had some questions sinse the F22a is a lot bigger will this be a problem swaping Im mainly worried about if the transmission will fit properly. I see a lot of how- to's for H22a swap for accords-civics wondering if anybody had any for this situation. Also If there are too many problems with this would I be better off going with a GSR. Also which do yall think would be more of an advantage?
See You @ the track
Just Accept It!!! It's okay for Four cylinders to beat Eight Cylinders...
95 Honda Del Sol
94 Honda Accord
84 Dodge Aries
I ghost on the next lane and sometimes the cops
Old 02-16-2005, 07:07 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
If its an h22 to civic guide it will be generally the same for the sol. And if i had an H22 just chillaxin id put it in my sol in a heartbeat.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 02-16-2005, 07:24 PM
Re: GSR vs. F22a
Its not though its the single cam version of the H22 but still has VTEC thats Why I wanted to know would it be better to to have a smaller but DOHC or a bigger engine with single cam considering they both VTEC.
95 Honda Del Sol
94 Honda Accord
84 Dodge Aries
Old 02-16-2005, 10:46 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: GSR vs. F22a
Go with the B18C1 it has a bigger aftermarket than the F22A.
Old 02-17-2005, 12:17 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: GSR vs. F22a
to my knowledge, an F series engine won't fit in a sol mainly because no one makes mounts for it.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 02-17-2005, 04:43 AM
Re: GSR vs. F22a
Do yall have some lists of some sites I can go buy engines, mounts, tranny's, wiring harnesses. Why couldn't I just use the mounts from my Accord and do some minor refabrication. I really dont want to spend the money to buy a new engine. Yall have been really helpfull though. Thanx. Either way the car is going to be fast as fuck!!
95 Honda Del Sol
94 Honda Accord
84 Dodge Aries
Old 02-17-2005, 04:09 PM
94SolGrl's Avatar
Re: GSR vs. F22a
Dude.... do not TOUCH your engine... please... until you sit down and research... a lot.... Why won't accord mounts work? Cause the accord is a DIFFERENT CAR... The only cars that the del sol shares pieces with is the 92-95 civic, and there's a FEW CR-X pieces that bolt on here and there.
~*Emily*~
HOW TO POST PICS!
Old 02-17-2005, 06:53 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: GSR vs. F22a
Putting an F motor in a Sol is the worst idea i have ever heard. That engine is so weak. You'd be better off putting the D series SOHC VTEC in one if you don't want to pend a lot of money. By the way, The F22 is in no way shape of form the SOHC version of the H22. They are dofferent all together. Only the DOHC VTEC mtors were built with performance in mind, so i would go with one of those if i were you.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 02-17-2005, 08:40 PM
Re: GSR vs. F22a
Thats why I have a lovely forum like this to ask questions before actually acting upon it. Okay so I understand now that the F22 is prolly not the best descion then. Of coarse not stock but I was planing on rebuilding it......maybe not now. We have two Del Sol's in our Car Club with LS's & GSR's in them. if you said that the only peices that bolt up right with a del sol is a 92-95 civic and a few CRX how is this possible. Is it because there is a big market for mounts and pecies for these engines like whtteg said earlier. It makes sense..... Yo guyz thanx for all the help and answers.
95 Honda Del Sol
94 Honda Accord
84 Dodge Aries
Old 02-17-2005, 11:23 PM
whtteg's Avatar
Re: Re: GSR vs. F22a
Yes the LS and GSR swaps are very common and I think you can just use a set of Del Sol VTEC motor mounts to bolt in a B18A,B,orC.
Old 02-18-2005, 10:45 AM
NA is Best!
Re: GSR vs. F22a
Ok, so i was grossly tired when i wrote that and seriously thought you said H22 not F22 hah. Yea, in that case, id go with the GSR.
Old 02-18-2005, 12:21 PM
94SolGrl's Avatar
Re: GSR vs. F22a
The only F series motor I would even remotely think about trying to wedge in a sol is an F22C1.... the S2000's powerplant.
and the parts bolting up isn't because there's a bigger market... it's because the chassis is basically the same... the sol was originally built on a CRX chassis, which is why the 92 and 93 sols VIN number starts JHMEH6... EH6 is the CRX chassis code... 94 and after, it's JHMEG2, which is the 92-95 civic code.
~*Emily*~
HOW TO POST PICS!
Old 02-27-2005, 01:20 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: Re: Re: GSR vs. F22a
Yeah, that's right. The Del Sol VTEC mounts are B-series mounts and are compatible with any other B-series motor. Integra motor mounts will work as well - they're the same ones I believe as the Sol VTEC mounts.
GhostRyder:
The F22A is a SOHC economy engine. It has decent torque, but if you're looking for something on the performance side, you're better off either sticking with the D16Z6 or any B-series motor for your Sol. The swaps are very common so you have a lot of aftermarket support and frankly you have more options available for performance upgrades on a B-series or D-series motor than you do the Accord F-series. The D16Z6 can be had relatively cheap or a B18B1 (Integra LS) is also typically inexpensive compared to the VTEC motors.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
