Old 02-15-2005, 11:26 PM
Suffakate Suffakate is offline
Send a message via AIM to Suffakate
Car Idles high, low, high, low, high low.........
Yeah at first the car only did that in park and neutral, now i notice that it will do it when im at a stop light. i can make it go away if i put the car in park and rev it, than put it back into drive...... the car is a 91 accord
Old 02-16-2005, 07:54 AM
Ehscrewdude Ehscrewdude is offline
Send a message via AIM to Ehscrewdude
Re: Car Idles high, low, high, low, high low.........
what is the range of the rpms we are talkin about? (ie: 1000-5000?)
Old 02-16-2005, 10:15 AM
Igovert500's Avatar
blue + red light magnet
Irratic idle is usually caused by bad spark plugs, bad 02 sensor, or vacuum leaks.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-17-2005, 10:30 AM
94hondaacc 94hondaacc is offline
There Is A Screw Inside Your Throttle Body That Comes Loose. You Have To Remove The Throttle Body Open The Little Cover On It, And You Will Have A Screw That Is Holding Down A Spring. The Spring Has Probably Come Loose And Will Need To Be Put Back In Place By The Screw. Good Luck.
