Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-16-2005, 12:18 AM
mustange kiler mustange kiler is offline
brake light on
hey my brake light will come on ever time that i come to a stop and when i turn real fast and when i have wheel hoop. it comes of when i stop on the gas and when i come to a complet stop. i guesse it might have something to do with my suspension?
Old 02-21-2005, 01:33 AM
macder macder is offline
Send a message via MSN to macder
Re: brake light on
Check your brake fluid level, not sure about 2g's but the 1g's have a sensor in the brake fluid container. So if it reaches a certain level, it would trigger the brake light.
BTW, im assuming your handbrake light on the console is turning on.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
