Old 02-15-2005, 08:50 PM
camaro5544 camaro5544 is offline
Unhappy Camaro will not start
I have a 1995 camaro v6 3.4 and it will not start, it will turn over but not start does anyone know what would cause this.
Old 02-15-2005, 09:49 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: Camaro will not start
fuelpump?? new starter, im just guessing
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 02-15-2005, 11:03 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
you gotta see if you are getting spark and fuel.
*Better power-to-weight ratio than a C6 corvette*
Old 02-16-2005, 01:04 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
and i'm betting that it's not getting fuel.
Old 02-16-2005, 02:27 AM
tweak177 tweak177 is offline
Send a message via AIM to tweak177
easiest way to find out is spray some starting fluid in your carb or throttle body or even pour a little bit of gas down there and try starting it. if it fires up then its either your fuel pump or fuel filter. if it doesnt then its probably your coil.
Old 02-16-2005, 08:00 AM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
if you have a spark tester just take a plug wire off and hook it from the end of your plug wire to the spark plug, thats usually the way i check for spark.
do you hear the fuel pump come on when you turn the key to on?
Old 02-16-2005, 08:26 AM
BrakeTorque's Avatar
BrakeTorque BrakeTorque is offline
Most likely its your fuel pump, listen for a buzzing noise under your car when you turn your ignition on. If you dont hear anything then its your fuel pump. If you hear it check plug wires. Other then that Fuel/spark has to run.
" easiest way to find out is spray some starting fluid in your carb or throttle body or even pour a little bit of gas down there and try starting it"
Old 02-16-2005, 08:06 PM
it is not the fuel pump or fuel filter and it is getting spark
Old 02-16-2005, 08:09 PM
i also tried the starting fluid and it did nothing
Old 02-16-2005, 10:38 PM
v8soldier v8soldier is offline
Send a message via AIM to v8soldier
This is just a theory and probably a longshot at best but if you have an injector stuck open it can fill a cylinder with too much gas. I've seen it once or twice before on a couple 4 and 6 cylinder cars. The injector will stay open when you turn the car off and whatever fuel is between the pump and the injector will dump into the cylinder. It's kind of like flooding a carbureted engine, makes it damn hard to start. Hope I could help man.
Old 02-17-2005, 12:14 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
if you have fuel and spark, then the last thing it could be is the timing. somebody probably took the distributor off and rotated the rotor, so now the timing is off. Or somebody has the spark plug wires going to the wrong cylinders. stuck open injector is possible too, but I wouldn't say likely.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 02-17-2005, 12:26 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
It can't possibly be the distriutor, it doesn't have one. But it could still be the timing...How do you know for sure it is not the filter or pump???
Old 02-17-2005, 09:38 AM
FlawedByNature FlawedByNature is offline
Send a message via AIM to FlawedByNature
in my case, i could hear the pump activate when you turn the key, but no fuel was getting to the system. as it turns out, the fuel pump was broken inside my tank and was working.... but it was just pumping gas around in circles inside the tank.
that could also be it, but starter fluid shouldve worked if its a TBI like mine and the pump was the problem.... hmm
Old 02-17-2005, 11:22 AM
Well if you think its none of thos 2 then it is timing. From what is happening i still think its your fuel pump, the fuel filter shouldnt cause it not to start but maybe harsh idles and bad fuel comsumption. check it with a timing light
Old 02-17-2005, 12:00 PM
oh.. i didn't realize it was a 1995 camaro... i don't know about that optispark shit. but even still, if its getting fuel then that eliminates the filter and pump (assuming that he checked it correctly). Even if he didn;t check it correctly, starter fluid would have made it run for a second or two. I would have the timing checked
