Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 02-15-2005, 08:44 PM
rjac1 rjac1 is offline
93 Corolla starting problem
The 93 corolla is in great shape (up until now). The car was just inspected with no problems in Texas passed all emissions tests and was running fine. Drove it out of town saturday about 200 miles no problems. Drove it local about 5 or 6 times sunday no problems. Parked the car for about an hour went out to use it again and it would not start it turns over but will not fire up. I have checked the following:
fuel pump is pumping gas at the fuel tank
fuel pump is pumping gas through the fuel filter
timing belt is in tact and turning the engine
I see no loose wires or burnt fuses at least the ones i can check by sight
it is not returning any trouble codes
I am at a loss as to what would cause this so suddenly with no warning. The car was running very well no missing , stumbling, rough idling or any other warning signal that there might be a problem. any comments or suggestions would be appreciated. I did a search but did not find anything on this topic. thanks in advance for any help you may be able to provide.
Old 03-04-2005, 01:22 PM
jhong1226's Avatar
jhong1226 jhong1226 is offline
Re: 93 Corolla starting problem
check your ignition coil, it may have stop working.
