Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-15-2005, 07:01 PM
Creeksurfer Creeksurfer is offline
94 JGC Transmission/Driveshaft Alignment
I lowered the transmission from its mount to drop the exhaust system. Upon raising the transmission to re-attach to mount, the slip yoke on the rear drive shaft does not go back into the transfer case. It is cocked at an angle. Does anyone know why slip yoke will not slide in. Is there a spline where teeth need to intermesh? Could low fluid in the transfer case cause this? Please help.
Old 02-15-2005, 08:20 PM
JDPascal JDPascal is offline
Re: 94 JGC Transmission/Driveshaft Alignment
Quite likely the slip yoke has come off the splines far enough to allow the wheels to turn. This allows for mis-alignment of the splines.
Lower the transmission enough to turn the wheels and align the splines or just remove the driveshaft and reinstall it correctly.
JD
Old 02-15-2005, 11:30 PM
mx52nv's Avatar
mx52nv mx52nv is offline
should have marked prior to removal.
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
