Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-15-2005, 06:47 PM
jimmy4x4 jimmy4x4 is offline
speedometer doesn't work
i have alot of problems man but i paid $600 for my jimmy and it's been good to me so if you can tell me why my gauge doesn't work i might just give you a big kiss.
Old 02-16-2005, 03:29 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: speedometer doesn't work
please supply all information.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-16-2005, 11:38 AM
the needle and tach and mileage don't move
Old 02-16-2005, 01:21 PM
BlazerLT's Avatar
AF -Advisor
no, I meant the year, the engine, the truck, did you do any repairs that might have caused it?
Old 02-16-2005, 03:13 PM
oh my bad its an 85 2.8L V6 and i bought it broken
but i got everything else in it to work except the speedo oil gauge and rear defroster
Old 02-16-2005, 11:05 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: speedometer doesn't work
I think it has a vehicle speed sensor located on the rear of the tranny to measure the speed.
Old 02-17-2005, 11:41 AM
i'll check that out thanx
Old 02-17-2005, 03:09 PM
danjgrace danjgrace is offline
You sure got a great deal on your Blazer. Its basically the same truck as the Jimmy. The only other trouble I have had was the rear latch switch was running my battery down. Found a lose ground wire. Also the battery and alternator went out this past year and after the second alternator, I found a loose block ground wire from the battery causing all of it!
Old 02-19-2005, 11:16 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Actually you don't have a speed sensor in the 85, you have a gear (as your speedo is cable driven). To check the cable, pull the cable off the tranny and hook it to a drill, fire up the drill, if your speedo moves it's your speedo gear on the tranny, easily replaced. If it doesn't move it's most likely either the cable is bad or fell off the back of the speedo behind the cluster. As to your tach check the wire with a multimeter to your coil. Probably a break in it somewhere...I don't have access to those diagrams for your year but any dealer should let you look at their books..
