Go Back   Automotive Forums Car Chat > Mitsubishi > Mighty Max
Old 02-15-2005, 06:30 PM
gremillac gremillac is offline
Starting question???
Hello.
My Dad bought a 90 Mighty Max and it runs like crap unless you keep the key turned in the start position(turned clear over and hold on like your cranking it) then it runs good?
He tuned it up, put a new switch on and a new starter, but it still does it? Any ideas why? Tnx, Rod
Old 02-15-2005, 07:07 PM
dinoraver3466 dinoraver3466 is offline
Re: Starting question???
never heard of that... possible bad ecu..... i would check plugs on ign. harness..... no alarm in it..?????
Originally Posted by gremillac
Hello.
Old 02-16-2005, 07:25 PM
slmd90mitz slmd90mitz is offline
Send a message via Yahoo to slmd90mitz
did you check the timing, some ecu actually retard timing as engine is starting to make for easy starting, if the key is turned it would keep the ecu in the starting mode if the timing is a little off this could cause it to retard it in to proper timing
Old 02-16-2005, 08:40 PM
Re: Re: Starting question???
you would have to have skipped a couple of teeth... but good point............... try advancing the dizzy and see if she'll run......
