Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-15-2005, 05:12 PM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
what size turbo to use?
my firend says that a t3/t4 would be too small for a turbo set up on my sohc.
my stock motor motor can hadle about 8 psi, or is that too much?
does any one know a good manufaturer of good turbo maniolds for under 150, ive seen bad things from obx.
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 02-15-2005, 05:35 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: what size turbo to use?
i think a t3/t4 is a good size turbo for a sohc. all depends on how much whp you plan on making. but for a stock motors,thats a good size
Team Lonely Drivers
Old 02-15-2005, 05:54 PM
turboEKhatch turboEKhatch is offline
A T3/T4 can support 350 horsepower, it can support 800 horsepower. Don't take any shred of advice from someone who doesn't know that there are thousands of variants of T3/T4's, or someone who says one is too small for your car. Furthermore, boost pressure is irrelevant, because 8 psi on a T25 is totally different from 8 psi on a T3/60-1. No, you arn't going to find a good new turbo mani for under 150 bucks. For a good turbo for your SOHC I would run a T3 .48 A/R with a 60-trim compressor side, on a drag manifold, both of which can be had fairly cheap.
Old 02-15-2005, 05:57 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Get a ('88-'95)CX, VX, STD, or HF manifold; buy a adapter flange and there ya go. Lots of people use those manifolds with cheap home made turbo kits. But of course a manifold ment for turbo would be better, but it would be cheaper.
Old 02-15-2005, 06:16 PM
while running around 8psi on the t3/t4. what FMU should i use? 4:1 ? 12:1 ? what?
what dimensions of an intercooler will fit around my bumper area.
what is a "Drag" manifold? i know what a turbo manifold is, but how are the two similar or differant?
Old 02-15-2005, 06:58 PM
CivicSpoon's Avatar
There is no Spoon
I'm assuming he ment the company Drag.
Old 02-15-2005, 10:26 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
johnnyracecar.com for your intercooler, dont use an fmu, get something electronic, and i doubt you are gonna find a manifold for 150.
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 02-16-2005, 08:30 AM
well, my turbo. what FMU should i get?
Old 02-16-2005, 03:17 PM
97CivicX's Avatar
afc, emanage, uberdata, hondata
Old 02-17-2005, 07:43 AM
how do things like hondata plug in? into the ecu? does it just overide a lot of things? does it take the place of the ecu? how exactly does it work?
Old 02-17-2005, 09:05 PM
97CivicX's Avatar
check out the faq/forums on hondata.com. all youll ever need to know is there. basicly you need an obd1 ecu which has to be chipped, then using a pc you can tune almost all aspects of your car's engine
Old 02-17-2005, 10:45 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
$150 for a good manifold..................
try blox or inlinepro for if your looking for a good cast mani.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 02-18-2005, 10:11 AM
how do you convert your engine from obd2 -> obd1 ?
Old 02-18-2005, 12:52 PM
get a obd2 to obd1 conversion harness
Team Lonely Drivers
Old 02-18-2005, 07:31 PM
ok now, when it comes gsr swap time, what will be needed to convert the turbo system? like the exhaust manifold and what else?
