Old 02-15-2005, 01:54 PM
roaingphantom roaingphantom is offline
Headlamp bulbs
Hello all,
I was advised to change the stock headlamp bulbs with sylvania silverstars for maximum lighting and a better look on my 2004 LS. My concerns are...(1) would it void my warranty and (2) based on the amount of heat produced i was told it could melt the wiring which would then void my warranty. Are these statements true?
Thanks
Old 02-15-2005, 01:59 PM
Mr. Northface's Avatar
Mr. Northface Mr. Northface is offline
Pretty much every one of the aftermarket headlamp bulbs I have found will NOT void out your warranty.
I added some aftermarket bulbs (the names of which I can't remember) that are 80watt low beams & 100 watt high beams & I have had absolutely NO problems whatsoever. If there is any additional heat generated from the bulbs, it hasen't effected my headlights at all. Plus they aren't any hotter to the touch over the standard bulbs.
2003 TrailBlazer EXT 4X4 NorthFace Edition. Silver Green over Pewter
Every option minus the DVD 4 a MoonRoof.
5.3 V8 3.73 Locking Rear.
Performance:
TrueFlow Air Intake
Granatelli Mass Flow Air Sensor
FlowMaster 70 Series SUV Muffler
Predator Power Programmer
Airaid Throttle Body Spacer
Misc.:
Super White headlights 80W & 100W
Fog Lamp bulbs
Billet Grill
XM
Tekonsha Prodigy Brake Box
Valentine 1 Radar
Line Of Fire 49" L.E.D Brake Light
Old 02-16-2005, 06:25 AM
ZsTB ZsTB is offline
I had KYO 4500K bulbs (CRAP), had them in for about 6 months and they melted the harnesses for both the driver and the passenger sides. The dealer at first was not going to replace the harnesses under warrenty, since the KYO bulbs where deemed the cause. After some coaxing I finally got them to replace the harnesses. Or you could go to Lowes and get a heavy duty harness for a couple of buck and replace them your self.
Thanks Chris
Old 02-16-2005, 11:00 AM
BlulytesTB's Avatar
BlulytesTB BlulytesTB is offline
No problem w/ the silverstars... had them for over a year... no harness problems... no void warranty...
silly... who told you that?
Old 02-16-2005, 08:10 PM
The makers of the bulbs that I bought I think were:
GP Thunder with a rating of 8500K
Going down the dark roads that I do, I hold the pass to flash feature back lighting up the low beams & the highs at the same time & I still have had no problems. I normally would hopld it for lengths of 10 seconds & longer......
Performance:
TrueFlow Air Intake
Misc.:
Fog Lamp bulbs
Billet Grill
XM
Valentine 1 Radar
Old 04-08-2005, 11:59 PM
bigj1 bigj1 is offline
Re: Headlamp bulbs
Like ZsTB, I too had installed cheap high vis bulbs (55watts) in my LTZ and the plugs and wiring melted down.
The wiring for the low beams are an awfully flimsy gauge so be ware.
