Old 02-15-2005, 11:27 AM
ringersoll1869 ringersoll1869 is offline
Gas Mileage has gone to crap
Hi guys,
My gas mileage in my 2000 Blazer LT has gone from close to 300 a tank to about half that. Not sure what's going on. No SES Light coming on. I did plugs wires cap and rotor about 3 months ago. Not sure where to start. Would the fuel filter be causing that?
Need help badly. Gas is too expensive to not be getting good mileage.
Old 02-15-2005, 11:48 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Gas Mileage has gone to crap
How many miles are on it?
What kind of plugs did you use? What did you gap them at?
What does your temperature gauge say when the engine is warmed up?
Does it run okay? Any spitting, sputtering, or stalling?
Can you smell gas?
Unrelated:
If you haven't done so yet you are do for some fresh anitfreeze, too. You also need to replace your radiator cap with a Stant from Advance Auto (stant is the best, but anyone other than AC DELCO will work). The AC DELCO cap that came on these trucks are defective and will cause you lots of problems if not changed out.
Old 02-15-2005, 11:57 AM
JoshBarber JoshBarber is offline
Originally Posted by ringersoll1869
Hi guys,
DEFINATELY! Change the fuel filter dude. Look up my recent post about it. Mine was disgusting ( I just bought the vehicle ) black shit poured out of it. HUGE difference in mileage after that. Also, what temp are you running at normally? As you'll see on here, it's a common issue for the Thermostat to go, and if the vehicle isnt running hot enough, it Kills mileage.
Old 02-15-2005, 12:51 PM
Plugs are regular bosch platinum. Temperature doesn't make it to 210 like it used to, but it not too far away. I haven't changed the radiator fluid since I bought the thing almost 3 years ago.
Old 02-15-2005, 12:52 PM
Sorry, also no gas smell or sputtering or stalling. Power hasn't been right though. Seems like the cars hesitates some.
Old 02-15-2005, 01:01 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Re: Gas Mileage has gone to crap
Start with the basics. A new Fuel Filter is at the top of the list, then the Air Filter and PCV Valve as well. You might also try some injector cleaner in the gas tank too. The Bosch plugs might be a mistake! If so, you'll hear about it from the others on this Forum, I'm unsure about these specific plugs.
Old 02-15-2005, 01:21 PM
blazee's Avatar
Problem?
Bosch was an extremely poor choice, don't feel bad though I've made the same mistake. They are probably part of your problem. Where did you get them from? The autozone here advertises Bosch and will give you your money back if not satisified.
Change the fuel filter, air filter, and PCV valve as Rick said.
Where exactly on the gauge does it show? If the thermostat is stuck or partially stuck your economy will suffer.
You definitetly need to change your coolant. As old as it is, you need to inspect it for signs of sludging. If there is sludging it will need to be flushed and refilled. Then replace the cap with a Stant brand....anything but AC DELCO.
Old 02-15-2005, 02:49 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
There is one of your problems.
Remove the Bosch plats and install only AC Delco Plats gapped properly.
Also, replace your air filter, fuel filter, PCV valve, clean your MAF sensor.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-15-2005, 03:07 PM
hesitation could be those plugs you put in. everybody on here swears the Bosch Platinums foul easy and call problems in our engines.
Old 02-16-2005, 08:54 PM
westsider westsider is offline
what temp does your guys blazers run at. Mine runs at about one line past the midpoint between the 100 and 210 degree marks. Is this normal? By the way the weather is about 50 degrees F. if that makes a difference. Thanks for any help
Old 02-16-2005, 09:53 PM
BlazerLT's Avatar
AF -Advisor
perfectly normal.
