Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 02-15-2005, 10:51 AM
dat1laosguy's Avatar
dat1laosguy dat1laosguy is offline
help 1st piston is out
I plugged in an ecu I bought off of ebay, it burnt my alternator fuse don't know how but now im running on only 3 cylinder. Where do I start looking to fix this? How do I fxis this? Is there away?
damn i can barely see you in my rearview mirror
Old 02-15-2005, 11:00 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: help 1st piston is out
oh god I can't believe you bought one of those ebay chips. Start with your sparkplug and sparkplug wire for that cylinder.
Empty Pockets Racing Member #1
Old 02-15-2005, 11:15 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Take out your 'ebay' ecu... find your old ecu... plug it back in... fix any other problems you may have caused... learn to research things a little better..... done.
Honda Enthusiast
Old 02-15-2005, 05:40 PM
Re: Re: help 1st piston is out
i have already taken off the ebay ecu and plugged in the original ecu.
i replaced the fuse to the alternator and now the only problem is i'm runnung on only 3 cyclinder
Old 02-15-2005, 09:53 PM
Killa_CRX's Avatar
When Civics Attack!
Re: Re: Re: help 1st piston is out
Check all your ignition components to the problem cylinder... if need be, replace your plugs (use NGK plugs, like you're supposed to), plug wires, rotor, and distributor cap...
If you still have a problem, see below.
Possible injector problem..
To check the injector, take a long metal rod (perhaps a long screw driver) and place it on the injector itself (metal to metal)... if you hear it clicking, the injector is working properly (compare with the other injectors for any apparent problems)... if the injector is working, make sure it's getting fuel.
Honda Enthusiast
Old 02-16-2005, 11:30 AM
louie3888 louie3888 is offline
You might want to check the following areas!
Fuel injector clogging, fuel leakage, air leakage
. Fuel injector circuit open or shorted
. Spark plug carbon deposits, fouling, malfunction
. lgnition wires open. leaking
. Distributor malfunction
. ComDression low
. Valve clearance out of spec
. VTEC system malfunction (D16Y5, D16Y8. 81642 engine)
. HO2S
. HO2S circuit
Good Luck
