| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
Twin remote mount turbo?
I know many don't like the Idea of the remote mounted turbo, but it makes sense to me.
So my idea is this: STS claims that moving the turbo to the rear has cooling benefits, less heat in the turbo, and such things as that. Now, from my reading on their website I have gathered that the reason they want you to use alky injection over 5psi in the LS1 powered cars is becuase of heat, correct? Correct me if I'm wrong, but is that not the reason for the injection, that is to say, cooling the air charge down more? Now, they also say that the run forward in the tubing acts like an intercooler because it's open to the air. Okay, good, so a single turbo can run 5psi on a LS1 car without alky or water injections. Now, what do you say to this: Get a true dual exhaust kit, two seperate runs to the back of the car. Then take two of the kits from STS (I know they wouldn't fit without fabbing something up, but put that aside for this example) And run them both, one on each side, at 5psi. Two seperate runs forward means you have twice the cooling. Then right before the throttle body or somewhere as you bring the tubing up to the throttle body you have your two air lines join. Any comments? If that wouldn't work, then why not get a custom intake manifold to basically have a pair of 4cyls on a common crank? I also want to ask about taking a chevy 572 and turning it into an EFI engine and putting a turbo system on that as well. If that one would be done, I'd likely do that instead of this twin set-up on the LS1. Feel free to blast holes in my ideas. |
Re: Twin remote mount turbo?
Besides not being a fan of the STS setup, that sounds fine. Don't give STS any money though, just buy your true dual system, buy a pair of t3 turbos, buy flanges for them, take it to a muffler shop and have them weld the flanges onto the exhaust where you want the turbos to sit. Then using silicon hose connectors and some straight and mandrel bends, run your intake piping. Or you could have that welded up too. Shouldn't cost you more than $700 if you know where to spend your money.
That's an interesting twist, I hadn't thought of that.
STS say their turbos are a weird size suited to remote mount. So how would I go about finding what that size is? |
If you know how a turbocharger works you know a remote mounted turbocharger isn't the way to go.
The advantages STS claims are just bogus. Fix yourself a real turbosystem instead, it's worth the extra work. |
I have some thoughts on that. I read the older closed remote turbo thread and most of the people against them kept saying "They will work, just not as efficient as a normal system".
So taking that into it, saying heat is part of what drives a turbo and all of that jazz, I have to say something. When you have your standard turbo system under the hood, you get lots of extra heat to deal with. Now I'm not saying heat is bad for a turbo, it's bad for the air charge and the components around it. Now you'll say that an under the hood turbo mounted just off the exhaust manifold will work better-more efficient. But then consider this: You need an intercooler to keep KR from getting out of hand. What's the normal pressure drop in an intercooler? I think it's somethign around 2-3psi, unless I'm not remembering correctly. However, with the remote mount you get cooling on the run forward with no more then 3/4 psi boost drop. So saying a standard turbo makes more boost at the same throttle on the same car as a remote mount, what could the difference be?? If it's more then 1-2psi then STS would not have gotten the GM design award. And the remote mount makes up for this lack of efficiency in the turbo, by having better efficiency in the cooling of the air charge. That is my reasoning for trying the remote mount, because it makes logical sense. I don't want to start a big fight again like in that other topic from back in mid-2004, I was just pointing out that's my reasoning. You believe that heat is required to make the turbo perform it's best, I don't. It's that simple. I'll take your advice, and I am looking into standard configurations for the LS1 turbo. And speaking of that, I have a twin-turbo setup for a Commodore/GTO LS1 that I'm looking at. Any of you think it'll fit in a Camaro LS1? |
Re: Re: Twin remote mount turbo?
Heat is bad in the compressor side. If you have a heat problem with conponents close to the exhaust (turbine) housing, you just shield the sensitive items. Or duct air in. Quote:
Okay, okay.....
Heat does drive the turbocharger. Consider that EGTs drop about 300F going through the turbine housing. That alone is energy being returned to the intake. Read in any basic science book and it will say that heat is energy. Hot air ballons for example.
You may get cooling benefits from the STS system(probably not a whole lot) but you will get some lag from having to pressurize all that piping. STS has to size thier turbos differently to compensate for the lost energy(heat, noise, ect). They are probably much smaller turbine sizes. Size the compressor as you would a normal compressor, but you will have to toy with the exhaust size. If SaabJohan says it isn't the way to go, it isn't the way to go. Simple as that.
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
Well then let me change my question: Do any of you think that this kit will be any good? I think it's still under development.
http://www.airpowersystems.com.au/ls1/ls1.htm I was wondering if it could be made to fit a LS1 Camaro, maybe with some hammering and torching. |
Heh heh heh, it certainly LOOKS like fun...
List of BS: -Remote Turbos -Electric Turbos -That "Tornado" thing
<elmer fudd> Be vewwy vewwy quiet, I'm hunting Morons. Heh heh heh heh. </elmer fudd> |
Remote turbos are good for newer camaros and such because of the lack of underhood room. Even the V6 has very little room.
That's the main reason I was looking at them. In my opinion I need to have the turbo in the back or under the engine bay, maybe tucked up with the tranny.
Don't have my car yet so i'll have to wait to see if it'll fit there. |
If it hasn't been mentioned yet, you might pick up a copy of "MAXIMUM BOOST" by Corky Bell. It may help you a bit in the selection of your turbo kit. |
i like the idea of remote turbos, ive i had a v8 i would prolly use one. Just for their eas of use.
