Old 02-15-2005, 12:00 AM
The River 1982 The River 1982 is offline
Wastegate?
My friend said that the little thing that sits on the top and towards the front of the supercharger on my '97 GTP is a wastegate. I was just wondering if it has a wastegate and if you can somehow modify it to prevent it from limiting the amount of PSI that the supercharger can produce. I'm talking about the little little piece that looks like a turbo wastegate right after the throttlebody.
Old 02-15-2005, 12:25 AM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: Wastegate?
The amount of psi that the supercharger can produce is going to be limited to how fast you are spinning it.
The Boost Bypass Valve, can be modified so that boost kicks in sooner or later.http://www.mccgp.com/upgrades/boostb...ost_bypass.php
Old 02-15-2005, 02:08 AM
Re: Re: Wastegate?
Thanks for the info, I am curious if you have done this and also if it is safe. If you have, are the results positive or negative? Thanks again
Old 02-15-2005, 09:04 AM
2kBlkGTP 2kBlkGTP is offline
I've done it and so have alot of people. some say they noticed a change, I didn't notice anything from when it was closed all the way to open all the way. Its safe to do and it only takes like 5 min.
