Old 02-14-2005, 11:58 PM
unknown_sender12 unknown_sender12 is offline
vibration damper removal?
i have a 94 s-10 blazer 4.3L im trying to change my timing chain and gears but i cannot hold the vibration damper still to get the center bolt out any suggestions? Im using a breaker bar to get the center bolt out but i just keeps cranking over the engine.
Old 02-15-2005, 04:10 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Re: vibration damper removal?
put a couple of spark plugs back in and use the compression . unless you removed a lot of stuff, radiator etc, you probably don't have room for a hammer driven impact driver . assuming you don't have air tools available. It may be reverse thread , can't remember , good luck
